Utility to read ram timings
2,573 (0.38/day)
N.Ireland
Processor Core I5 4440 / 4430
Motherboard Asus z87-k / Gigabyte ga h97- d3h
Cooling Arctic freezer / Generic
Memory 8 gb Mushkin / Various
Video Card(s) Radeon 7850 cf / Gtx 690
Storage Samsung 850 EVO 250 gb / 2x1 terabyte hdds Wd 256 gb nvme
Display(s) Technika 32" / Asus 24` ips
Case Corsair
Audio Device(s) X-fi Titanium
Power Supply Corsair 850 w
Anyone know a good one ? Apart from cpu-z.I want something that reads everything.Tried systool,but I think it`s reading the figures wrong.
will A64 tweaker work on an intel system aphex?
LOL, I don't know. I really did not see that he needed it for an INtel System. He could try, no harm in that right.
Edit: It most likely will not work, sorry for the false hope. I Do remeber seeing something for intel though, it was Like i### forgot what those numbers were.
Tried everest ,but couldn`t find ram timings.It`s not very important,just surprised there isn`t something like this available
what about SPDTool for the mem tim ?
Well that worked ,but now I`m more confused.
What I want to do is change this
in my bios (see left).
What is the same setting for a ga 965p ds3 ?
I think its the refresh cycle time (tRFC)
cuz with my in the bios is 5-5-5-15-5-25-11-10-10-10 somthing like that not sure on the last four
I was just looking at some screenshots of the board's BIOS, and it seems the setting isn't there.
What revision is your board?
okay found my settings in the bios
DRAM CAS# Lactency 5
DRAM RAS# to CAS# Delay 5 DRAM Clocks
DRAM RAS# Precharge 5 DRAM Clocks
DRAM RAS# Activate to Precharge 15 DRAM Clocks
DRAM Write Rcovery Time 5 DRAM Clocks
DRAM TRFC 25 DRAM Clocks
DRAM TRRD 10
Rank Write tp Read Delay 10
Read to Precharge Delay 10
Write to Precharge Delay 11
hope it helps any
revision 1
:eek:it isn`t there:eek:
:confused::confused:
Ermm I don`t,but then again I don`t want it either.Think it would make a difference ?
New BIOSes generally improve performance, fix bugs, improve overclocking, and sometimes even add features. It's worth a shot.
tRC = Row Cycle timing
francis511,
What tRAS and tRP are you running? And to what value are you planning on setting the tRC?
btw,
Your system specs say you have a 8800GTS and a 17" Compaq CRT monitor? What resolution are you using for gaming? 800x600 like the screenshot earlier?
try memset,its very good.it also allows you to change your mem timings on windows.
francis511,
btw,
Resolution depends on the game ...
I`m currently running tRP and tRas at 5 & 18.
The reason why I posted is that I want to set the tRC manually to 23 in the bios but I can`t find it !!! I think like Wile e. said , my mobo won`t let me change the value.
