VB.NET IRC client help
184 (0.03/day)
Central Nebraska
System Name CORSAIR
Processor AMD Phenom 1090T x6 @3.2
Motherboard Gigabyte Ga-78LMT-S2P
Cooling High efficiency dust cooling
Memory 8GB GSkill DDR3 1333
Video Card(s) Sapphire Radeon HD3870 512MB GDDR4 PCI-e toxic
Storage Seagate SV35.3 ST3250310SV 250GB SATAII(Windows 7 Pro x64), 320GB Samsung SATAII(Storage and SuSE)
Display(s) Dell 20" LCD, Dell 17" LCD
Power Supply Antec Cool Blue 650W Modular
Software Windows 7 Professional SP1, Visual Studio 2010 Ultimate
Hello all... hoping someone can help me. When I run this code I get the line I returned confirming the socket is connected to the server, however immediately after the program stops responding and I get the "send error report" dialog. Any ideas?
Code:
Imports System.Net.Sockets
Imports System.IO
Public Class console_MAIN
    Dim Socket As System.Net.Sockets.Socket
    Dim StreamIn As System.IO.TextReader
    Dim StreamOut As System.IO.TextWriter
    Private Sub SetServerToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles SetServerToolStripMenuItem.Click
        Console_Server.Show()
    End Sub
    Private Sub ExitToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ExitToolStripMenuItem.Click
        Me.Close()
    End Sub
    Private Sub ConnectToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ConnectToolStripMenuItem.Click
        StartConnect()
    End Sub
    Public Sub StartConnect()
        Dim ServerAddress As String = My.Settings.ServerAddress
        Dim ServerPort As Integer = My.Settings.ServerPort
        TextBox_MsgIn.AppendText("Initializing connection..." & vbCrLf)
        Dim ipHostInfo As System.Net.IPHostEntry = System.Net.Dns.GetHostEntry(ServerAddress)
        Dim EP As New System.Net.IPEndPoint(ipHostInfo.AddressList(0), ServerPort)
        Socket = New System.Net.Sockets.Socket(EP.Address.AddressFamily, Net.Sockets.SocketType.Stream, Net.Sockets.ProtocolType.Tcp)
        Socket.Connect(ServerAddress, ServerPort)
        'send PASS
        Send("PASS " & My.Settings.ServerPassword)
        'send NICK
        Send("NICK " & My.Settings.Nick)
        'send USER
        Send("USER " & My.Settings.Nick & " 0 * :RoX Player")
        Connected()
    End Sub
    Sub Send(ByVal msg As String)
        msg &= vbCr & vbLf
        Dim data() As Byte = System.Text.ASCIIEncoding.UTF8.GetBytes(msg)
        Socket.Send(data, msg.Length, SocketFlags.None)
    End Sub
    Sub Connected()
        Dim ConfirmConnect As Boolean = False
        Dim PasswordSet As Boolean = False
        If My.Settings.ServerPassword <> "" Then
            PasswordSet = True
        End If
        While Socket.Connected = True
            If ConfirmConnect = False Then
                TextBox_MsgIn.AppendText("Connected to " & My.Settings.ServerAddress & " on port " & My.Settings.ServerPort & " using password: " & PasswordSet.ToString)
                ConfirmConnect = True
            End If
            Dim mail As String = recv()
            If mail <> Nothing Then
                StreamOut.WriteLine(mail)
                TextBox_MsgIn.AppendText(mail & vbCrLf)
            End If
        End While
    End Sub
    Function recv() As String
        Dim data(4096) As Byte
        Socket.Receive(data, 4096, SocketFlags.None)
        Dim mail As String = System.Text.ASCIIEncoding.UTF8.GetString(data)
        If mail.Contains(" ") Then
            If mail.Substring(0, 4) = "PING" Then
                Dim pserv As String = mail.Substring(mail.IndexOf(":"), mail.Length - mail.IndexOf(":"))
                pserv = pserv.TrimEnd(Chr(0))
                mail = "PING from " & pserv & vbNewLine & "PONG to " & pserv
                send("PONG " & pserv)
            ElseIf mail.Substring(mail.IndexOf(" ") + 1, 7) = "PRIVMSG" Then
                Dim tmparr() As String = Nothing
                Dim rnick As String
                Dim rmsg As String
                mail = mail.Remove(0, 1)
                tmparr = mail.Split("!")
                rnick = tmparr(0)
                tmparr = mail.Split(":")
                rmsg = tmparr(1)
                mail = "msg: " & rnick & ">" & rmsg
            End If
        End If
        mail = mail.TrimEnd(Chr(0))
        mail = mail.Remove(mail.LastIndexOf(vbLf), 1)
        mail = mail.Remove(mail.LastIndexOf(vbCr), 1)
        Return mail
    End Function
    Private Sub Button_send_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button_send.Click
        Send(TextBox_MsgOut.Text)
        TextBox_MsgOut.Clear()
    End Sub
    Private Sub Button_Connect_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button_Connect.Click
        StartConnect()
    End Sub
    Private Sub console_MAIN_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        Label_CurrentServer.Text = My.Settings.ServerAddress
    End Sub
    Private Sub Label1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Label1.Click
    End Sub
End Class
Correction
Found that issue, now it hangs after the MOTD message is delivered.
Here si new code:
Code:
Imports System.IO
    End Sub
        Me.Close()
    End Sub
        StartConnect()
    End Sub
        'send PASS
        'send NICK
        'send USER
        'send MODE
        Send("MODE " & My.Settings.Nick & " +h")
        'send join
        Send("JOIN " & My.Settings.Channel)
        Connected()
    End Sub
        msg &= vbCr & vbLf
    End Sub
    Sub Connected()
        Application.DoEvents()
            PasswordSet = True
        End If
        Dim mail As String
        Try
                End If
                mail = recv()
                If mail <> "" Then
                        ' StreamOut.WriteLine(mail)
                    End If
                Else
                End If
            End While
        Catch ex As Exception
            MessageBox.Show(ex.ToString)
        End Try
    End Sub
                Dim rnick As String
                Dim rmsg As String
                rnick = tmparr(0)
                rmsg = tmparr(1)
            ElseIf mail.Contains(":") Then
            End If
        End If
        Return mail
    End Function
    End Sub
        StartConnect()
    End Sub
    End Sub
    End Sub
End Class
Okay... so I tested the code above, letting the program hagn and sending a private massage to the nickname the client was running under... and boom, the program stops hanging and displays the message.
So Im guessing this a thread issue due to the loop running on the main thread?
Yes, you'd have to put a listener on a separate thread that notifies the main thread of changes.
