Vista help please... already!
Jimmy 2004
5,458 (0.73/day)
England
System Name Jimmy 2004's PC
Processor S754 AMD Athlon64 3200+ @ 2640MHz
Motherboard ASUS K8N
Cooling AC Freezer 64 Pro + Zalman VF1000 + 5x120mm Antec TriCool Case Fans
Memory 1GB Kingston PC3200 (2x512MB)
Video Card(s) Saphire 256MB X800 GTO @ 450MHz/560MHz (Core/Memory)
Storage 500GB Western Digital SATA II + 80GB Maxtor DiamondMax SATA
Display(s) Digimate 17" TFT (1280x1024)
Case Antec P182
Audio Device(s) Audigy 4 + Creative Inspire T7900 7.1 Speakers
Power Supply Corsair HX520W
Software Windows XP Home
OK, so I've finally managed to download the beta from MS, and eventually got it installed ok but I have quite a big problem. The Vista bootloader seems to be at a different resolution and my monitor can't seem to display it without the writing jumping unreadably across the screen. I have a cheap LCD and I expect that's the problem but it makes it difficult to boot to XP. So I'd be grateful if someone could either advise me how I could add Vista to the XP bootloader and boot from that or if there is some way I could sort out my monitor... I try the auto adjust and it doesn't work! :confused:
safe mode
try to get into safe mode, and see if you can change the res there.it also may be the drivers are not compatible with vista.
if you could post a pic, that might help
Thanks for the help - Vista is fine once I'm past the bootloader screen and I don't think you can change the reolution of the bootloader. The problem is I can't read the screen to chose between Vista and XP, and because I can't read the screen I wouldn't be able to boot to safe mode anyway :laugh: ! I think I'll just give Vista a miss for now and put Ubuntu back on that partition.
