Vista network problem
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
Processor E8500 Core 2 Duo, 1333Mhz FSB, 3.16Ghz @ 4.5GHz (got into Windows @ 4.75GHz)
Motherboard ASUS P5Q-e
Cooling CPU Cooler - TT V14 Pro, 2x120mm CM Blue LED fans, 1x90mm CM Blue LED fan
Memory G.Skill Pi 4GB (2x2GB) Dual Channel DDR2 PC8000 (1000MHz), 5-5-5-15
Video Card(s) Sapphire HD4850 512mb with ASUS EAH4850 BIOS
Storage 2x 500GB Seagate 7200.12 Raid 0
Display(s) Acer AL1912, 19" LCD screen
Case Thermaltake Soprano Black ATX case
Audio Device(s) Onboard 7.1, Speakers - 5 + Sub + Monitor speakers
Power Supply Thermaltake 850W Toughpower Cable Management - Quad (2x18A and 2x30A) 12V rails
Software Win 7 Pro x64, MSN, CS:Source, etc etc
Ive installed Vista on my older P4 computer.
Everything installed fine, no issues.
The network all installed properly too. Both the onboard LAN device and PCI WLAN device.
The only problem is that the onboard LAN (cable connection) is REALLY slow. Both copying files over the network (from my computer) and downloading off the internet is slow.
Its weird...the internet is fast, its only when i go to download a file. For example, if i was to download the ati driver, going to the website will be really quick, then downloading the file will go at 5kb/s. Normally, it goes at 1.2mb/s off the ati site (just tested on this comp).
I tried downloading using the wireless network card, and even that goes at 800kb/s! (And thats on the same computer with the WIRED network card going at 5kb/s).
Ive tried different cables, no luck. Just to mention, it was working all good in XP.
Anyone know wats going on? (Please dont make this a "flame Vista" thread ;))
Thanks in advanced
Pinchy
6,270 (0.89/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
Pinchy try some runs on different servers here..lets us know how you get on. www.speedtest.net
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
lol, ive run it on stacks of servers.
All my driver websites (abit, card reader, etc) as well as speedtest. Same results, wired gets really slow speeds, wireless gets what its meant to.
BTW - thanks for the fast reply :)
6,270 (0.89/day)
New York
Did you let vista find the driver or did you get the vista driver from ASUS?
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
Its not on my new comp, its on my older comp.
Specs:
P4 2.6Ghz
1GB DDR
9800 PRO
80GB WD
Abit digidice
I let windows install my driver, once i realised it was stuffing up, i uninstalled it, downloaded the driver from abit (the XP one, because they got no vista one), it installed fine but still same problem.
6,270 (0.89/day)
New York
hmmm ....thats odd.What about firewall ? Are you running vistas FW or a 3rd party FW?
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
Vista's FW. I ruled the FW issue out, because it works fine on the same computer with the wireless connection.
(If something was to be blocked, it would be blocked on both the wired and wireless, not just the wired)
6,270 (0.89/day)
New York
when you run windows update does it find any thing in refrence to Nic card?
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
Nope, its all up to date.
6,270 (0.89/day)
New York
WOW , I'm stumped ...I did notice the drivers for that board are mostly 2004 with a couple of mid 2005's ... maybe that hardware is just struggling with the new IP stack ??? Although I dont find that assumption acceptable..Srry and good luck.
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
Yeah its a weird problem, which is why i posted on TPU :D
Thanks for trying tho
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
Weird....i just uninstalled the driver again and re-installed the downloaded ones, and its working perfectly again.
I think every other time i installed the downloaded driver, windows was installing the pre-configured one, so two drivers were installing at once, because this last time, i disabled the driver then installed the downloaded ones. (So windows wouldnt pick it up when it was uninstalled)
Just for the future, does anyone know how to turn off windows automatically installing drivers?
