Spaghetti_Bender
- Mar 3, 2019
- 5 (0.00/day)
Hello!
I have a FX8350 in a Gigabyte GA-990FXA-UD3 Rev. 1.0 motherboard.
Coolermaster hyper 212 Evo (upgrading to Noctua NH-D15)
Seasonic FOCUS Plus 850W power supply.
32 gb ballistic tactical 1866 ram 1. 5v
RX 580 GPU
Fractal meshify C case
I have been researching and trying to overclock my cpu for the last 1.5 years haha. I have never succeeded. This is a project I'll pick up every few months read some new material or watch some new videos and play around with my fx for a few days before I inevitably fail.
This time things are going to be different because I am going to ask for help.
Previously I was using a cooler master hyper 212 evo but now my cooling solution is a Noctua NH-D15. I used CPU-Z to monitor temps and clocks but in the past I got weird numbers. I read on another forum that cpu-z might not fully support my cpu.
So to begin with in bios I will turn off all the auto power saving and overclocking settings and rase the frequency to 4.2ghz or so but leave the voltage to stock but manually typed in. I'll set the ram to manual and type in the timings and try booting. Sometimes it works for a little while but after I try to run unigine heaven or play a game the computer freezes or crashes and I will have to clear the bois with the jumper on the motherboard and start all over. Temps would be high around 80 to 86C.
1. What are your suggestions for hardware monitoring software?
2. I have not tried the noctua cooler yet but I did try once more with my hyper 212 and ended up with the same results as before. Is there anything in the bios I should do first to increase the odds of success?
3. Is there any other information you need from me? I read though this forum for a few hours before I posted this first thread. So please help me out if I don't have everything in order for you all.
Thanks in advance!
RX 580 GPU
Thanks in advance!
