Wassercomputer.De
22 (0.01/day)
Washington DC
System Name AlphaCool Aquacomputer P5
Processor Intel Core i7-4960X @ 3.60GHz (OC 4.0GHz)
Motherboard MSI Big Bang-XPower II (MS-7737)
Cooling Aquacomputer and AlphaCool
Memory 16GB Corsair Dominator Platinum DDR3 SDRAM
Video Card(s) 3x EVGA Nvidia 980 1x Nvidia Titan X
Display(s) Acer XZ350CU Black 35" 21:9 Ultra-wide
Case Thermaltake Core P5
Power Supply Thermaltake 1350 Power Supply TP-1350M
Mouse Fenek Standard Issue Gaming Mouse- Black | 3310 Sensor, RGB
Keyboard Ducky Shine 6 Year of the Monkey special edition PBT Mechanical Keyboard (Silver Cherry MX)
Specs:
Operating System: Windows 10 Enterprise Edition (64-bit)CPU: Intel Core i7-4960X @ 3.60GHz (OC 4.0GHz)Motherboard: MSI Big Bang-XPower II (MS-7737)Memory: 16GB Corsair Dominator Platinum DDR3 SDRAMVideocard: EVGA NVIDIA GeForce GTX 980 (OC)Videocard: EVGA NVIDIA GeForce GTX TITAN X (OC)Videocard: EVGA NVIDIA GeForce GTX 980 (OC)Videocard: EVGA NVIDIA GeForce GTX 980 (OC)Hard Drive: KINGSTON SNVP325S2512GB (512GB)Hard Drive: Samsung SSD 840 EVO (500GB)Hard Drive: Seagate ST32000542AS (2TB)Powersupply: Thermaltake 1350 Power Supply TP-1350MCPU waterblock: cuplex kryos NEXT VARIO with VISION 2011/2011-3/2066, nickel/nickelCase: Thermaltake Core P5, Custom Acrylic Panel, 3D printed custom 5.25" bay.LED controller: Aquacomputer farbwerk USBFlow sensor: Aquacomputer Flow Sensor 'High Flow'Tubing: Thermaltake Pacific DIY LCS 1000mm Lengths V-Tubler PETG Hard Tubing (4-Pack) OD 16mm (5/8") x ID 12mm (1/2") CL-W116-PL16TR-ATubing adapters: Alphacool 18mm adaptersTube joints: Nanoxia jointsVideocard block: 1x Alphacool NexXxoS GPX GPU Waterblock, Nvidia Geforce GTX TITAN X / GTX 980 Ti M01, BlackVideocard block: 3x Alphacool NexXxoS GPX - Nvidia Geforce GTX 980 M02 Fans: 4x Asiahorse Wireless RGB LED 120mm Case FanController: Aquacomputer Aquaero 6 XT USB Fan Controller, Graphic LCD, Touch Control, IR RemoteController extra: Aquacomputer SPLITTY9 splitter for up to 9 aquabus devicesResivour: Aquacomputer Aquainlet XT 150 mL with Fill Level and Lighting Option | Nano Coated with Aquacomputer Pressure Equalization Membrane Radiator: Aquacomputer Airplex Radical 4/480Pump: Aquacomputer Aquastream - Ultimate Version----Periphrials: Monitor 1: Acer XZ350CU Black 35" 21:9 Ultra-wide Curved Monitor, FreeSync 144 Hz 4ms 2560 x 1080Monitor 2: Wacom Cintiq 21UX DTZ-2100D/G 21System display: Aquacomputer VISION Touch table top unit, glossy nickel plating, IR receiver and ambient temperature sensorKeyboard: Ducky Shine 6 Year of the Monkey special edition PBT Mechanical Keyboard (Silver Cherry MX)Mouse: Fenek Standard Issue Gaming Mouse- Black | 3310 Sensor, RGBMousepad: Custom Blue Counter-Strike mousepadHeadphones: Sennheiser HD 598 & Beats Detox ProDAC: S.M.S.L DP1 Digital Player Audio DAC with built-in Headphone Amplifier Microphone: Razer Seiren - Elite ProfessionalSpeakers: Boston Acoustics SoundWare XS Speaker and SubChair: AKRACING AK-PROX-GY-NA Gaming Chair
Mods:
Custom laser cut acrylic side panel.Custom 3D printed bay.Custom aluminum cut pedestal for the pump.Wrapped SLI bridge and power supply in brushed steel 3M wrap.
Built from old spare parts. I like how it turned out. First time doing stiff tubing.It powers all the latest pretty well even though it's a LGA2011 / X79 system :)
Aw man ;_; I hope I didn't do too bad. I am kinda still learning here.
Well you're off to a good start .. ima sucker for blue themed systems.why did you go with 3 980s and a titan?
I got a spare evga 980 I'll trade ya for that titan , :laugh:
I use the Titan for software development.
the 980's are for gaming in SLI. If the game I play doesn't support SLI very well, I move my monitor plug to the Titan. :)
Looks pretty swish.
The only gripe I immediately have is how obvious the I/O Panel is, everything else seems so well placed that a bare I/O panel just looks irksome.
Looks pretty swish.
Good idea, i didn't notice that. I will 3d print a cover and wrap it in brushed steel !
