- Apr 5, 2005
- 6,788 (0.92/day)
- Republic of Asia (a.k.a Irvine), CA
System Name | --- |
Processor | FX 8350 @ 4.00 Ghz with 1.28v |
Motherboard | Gigabyte 990FX-UD3 v4.0, Hacked Bios F4.x |
Cooling | Silenx 4 pipe Tower cooler + 2 x Cougar 120mm fan, 3 x 120mm, 1 x 200 mm Red LED fan |
Memory | Kingston HyperX DDR3 1866 16GB + Patriot Memory DDR3 1866 16GB |
Video Card(s) | Asus R9 290 OC @ GPU - 1050, MEM - 1300 |
Storage | Inland 256GB PCIe NVMe SSD for OS, WDC Black - 2TB + 1TB Storage, Inland 480GB SSD - Games |
Display(s) | 3 x 1080P LCDs - Acer 25" + Acer 23" + HP 23" |
Case | AeroCool XPredator X3 |
Audio Device(s) | Built-in Realtek |
Power Supply | Corsair HX1000 Modular |
Software | Windows 10 Pro 64 bit |
Last week I purchased the Thermaltake Water 3.0 Performer from Frys and I am ready to install it. But I have a question -
Pump 3 pin header - which fan slot on mobo should I plug it in?
1. Should I plug it into the CPU fan header and turn off PWM function
2. Any other 3 pin mobo fan header
3. Connect to the PSU directly?
If I don't plug into the CPU fan header, how will the mobo take care if there is a pump failure and shutdown the computer?
There is no software to monitor the pump, its only available with the Extreme edition.
This is the one I am installing now.
http://www.thermaltake.com/products-model.aspx?id=C_00002063
And which fan header is best to plug in the fans on the radiator?
Mobo is ECS A970M-A (for now), then will be switched to main gaming rig (Gigabyte 970A-UD3 V1.2)
Thanks,
Thanks,
