- Jun 14, 2021
- 2,567 (1.73/day)
- UK
I bought this a week ago M.2 Module Case for Raspberry Pi 5 , and just assembled it today . First thing was that the Keyboard did not work the mouse was working. they are both wireless.I thought i saw a message saying i did not have enough power ,i am using the the official PI 5 power supply,Then i thought i would take the top off i had not screwed it on lucky enough.
And found the the PI Active cooler was not working
It looks like the. NVME has been recognised it is a new one so not been formatted. I thought there was something with the batteries i tried the Keyboard on my Mac it works on there. I got this case after being unable to get the NVME to work on there.The Keyboard worked fine on there. So why is the fan not working ,the yellow wire is facing out to the NVME.
One thing i don,t like about the case is it does not have a on and off button like the DrskPI. I do like the metal case though. I don,t have a USB Keyboard to try on here .
Why would the mouse work and the Keyboard not?
[td]
I saw this but i can,t do anything without a keyboard
For the keyboard issue, ensure that the virtual keyboard is installed correctly. You can install the matchbox keyboard and set up a toggle script to enable the virtual keyboard. Follow these steps:
I see it now says failed to open NMVE
I did not think it had that problem ,it did not say that when i first tried it
[td]
Pi5 Waveshare Case Issues
If you are experiencing issues with the keyboard and fan not working on your Raspberry Pi 5 with the Waveshare M.2 case, there are a few steps you can take to troubleshoot and resolve the issue.For the keyboard issue, ensure that the virtual keyboard is installed correctly. You can install the matchbox keyboard and set up a toggle script to enable the virtual keyboard. Follow these steps:
