- Mar 28, 2018
- 1,900 (0.72/day)
- Arizona
System Name | Space Heater MKIV |
Processor | AMD Ryzen 7 5800X |
Motherboard | ASRock B550 Taichi |
Cooling | Noctua NH-U14S, 3x Noctua NF-A14s |
Memory | 2x32GB Teamgroup T-Force Vulcan Z DDR4-3600 C18 1.35V |
Video Card(s) | PowerColor RX 6800 XT Red Devil (2150MHz, 240W PL) |
Storage | 2TB WD SN850X, 4x1TB Crucial MX500 (striped array), LG WH16NS40 BD-RE |
Display(s) | Dell S3422DWG (34" 3440x1440 144Hz) |
Case | Fractal Define R5 |
Audio Device(s) | Edifier R1700BT, Samson SR850 |
Power Supply | Corsair RM850x, CyberPower CST135XLU |
Mouse | Logitech MX Master 3 |
Keyboard | Glorious GMMK 2 96% |
Software | Windows 10 LTSC 2021, Linux Mint |
I recently decided to replace my current monitor (Monoprice 35" 3440x1440 100Hz, bought in 2020) due to some issues I've had with it. The replacement is on the way, but in the meantime, I want to figure out what this one particular issue is.
Whenever Freesync is enabled, I randomly get this weird gray pattern on screen. It shows for maybe one frame, and then it's gone. I'd describe it as like a net or woven pattern almost.
Today, I decided to film the screen with my phone while running the NVIDIA G-Sync Pendulum demo, and I was able to capture it.
Click on the image to expand it.
So it's like the image gets divided into squares where every other pixel does weird things.
It seems to mainly happen when the refresh rate dips below 48Hz and LFC kicks in, and even then, it only happens occasionally. But when it does happen, it's extremely jarring and annoying enough that I don't use Freesync.
I've tried adjusting monitor settings, using a different DP cable, and even adjusting the point that LFC kicks in, and it still happens.
Anyone experienced something similar or know what exactly is causing this?
