Weird problem with my monitor
5,323 (0.86/day)
System Name [Daily Driver]
Processor [Ryzen 7 5800X3D]
Motherboard [MSI MAG B550 TOMAHAWK]
Cooling [be quiet! Dark Rock Slim]
Memory [64GB Crucial Pro 3200MHz (32GBx2)]
Video Card(s) [PNY RTX 3070Ti XLR8]
Storage [1TB SN850 NVMe, 4TB 990 Pro NVMe, 2TB 870 EVO SSD, 2TB SA510 SSD]
Display(s) [2x 27" HP X27q at 1440p]
Case [Fractal Meshify-C]
Audio Device(s) [Fanmusic TRUTHEAR IEM, HyperX Duocast]
Power Supply [CORSAIR RMx 1000]
Mouse [Logitech G Pro Wireless]
Keyboard [Logitech G512 Carbon (GX-Brown)]
Software [Windows 11 64-Bit]
I get this weird issue with my monitor whenever a program goes from full screen to the desktop and vice versa. Its like green/sometimes red fuzzies and the only way to make it go away is to refresh my resolution or turn the monitor off and on.
Is this something I should be worried about? Like should I be contacting asus about getting a replacement monitor?
Im using a ASUS VK246, and this is a fairly recent problem.
cell phone pic of the problem
I would check all connections, maybe try your monitor on a friends pc and see if the proble is still there
connections seem fine, dont have a second computer to test it on atm
I'd RMA the monitor.
odd issue, best of luck.
Sounds like cable problems to me
u sure? i just feel like its more likely a monitor would go bad then a cable randomly going bad. Cause it worked fine for months
Normally I would totally agree with it being a cable but because he can fix by turning off the monitor then turning it back on I would side with it being a monitor...but would also test with a different cable.
Maybe you accidentally disturbed it? Its just my hunch, though.
ill see if i can find another cable to test it with
I had almost same issue before...
its my video card's capacitors bloating.
you may need to check your's.
good luck
good luck
I was thinking a video card issue also, but why would turning the monitor on and off fix it? Thats the only reason I said monitor first.
Unless it is Win7 detecting the monitor turning off and disabling the port and re-enabling it when the monitor is turned back on(I know it does that).
