What are differences between Optimal and Adaptive power in nvidia panel?
Status
Not open for further replies.
Pit12
24 (0.01/day)
Hello. Fast question. What are differences between Optimal and Adaptive power in nvidia panel? I have Optimal. But sometimes in games i have fps drops which resulting in clock drop for one second. After second clock back again to normal.
So what are differences between Optimal and Adaptive power in nvidia panel?
My card is Gigabyte Xtreme 1080
63 (0.02/day)
Japan (Work) UK (Home)
System Name Top notch gaming PC - best HW as of 2019-2021 (Not the name of course)
Processor i9-9900ks @ 5.2 GHz
Motherboard AsRock Phantom gaming 9
Cooling Arctic Freezer ii 280
Memory 32GB G.Skill Trident z B die (out the box 17-19-19-39. 3,600MHz) Currently OCed 3700Mhz
Video Card(s) ASUS ROG strix 3080ti gaming OC 450w 1815 Mhz boost out the box.
Storage A lot of Samsung SSDs. Now Nvme 970 boot drive.
Display(s) New 2022 - AOC 273 27" new gaming monitor 1440p
Case Many. Main PC Thermal take full tower tt v71 Tempered glass
Audio Device(s) Now using EPOS external GSX 1000 2nd edition, Sound card. VZR spatial cans
Power Supply Seasonic Gold FX 850w (Several)
Mouse G703 Logitech
Keyboard A nice one.
Software Mostly games - Steam all block busters. VLC. F@H, Various Benches (Fires trike adv etc.)
Benchmark Scores Superposition 1080p EXTREME - 13125
Same question here. I always put gaming profiles to, "prefer maximum performance." But only games, all of them.
Global settings for everything else I am leaving at optimal. Of course I tried adaptive but couldn't notice any obvious differences. An answer from someone in the know would be good.
Currently both settings seem the same for me? I have not checked in great detail just normal GPUz, and HWInfo 64 readings, may be very subtle?
(GTX 1080 ftu). Same goes for my GTX 980 hof as well, that is no clear difference.
985 (0.21/day)
Ireland
Adaptive profile sets GPU clocks based on load, which means in basic games your card might run at very low clocks.
Optimal performance profile will keep you GPU at base clocks, even if game doesn't need so much of power.
Prefer maximum performance profile will try to use maximum boost clocks, based on load.
For example, difference is very noticeable in Arma 2/3 multiplayer where games performance is very limited by the server. Setting "prefer maximum performance" gives you much smoother experience, while i couldn't see any difference in single player mode. For most games i use adaptive profile, since GPU clocks are set based on GPU usage and it saves power whenever it's possible.
PS, i literally just woke up, sorry if I'm not being clear.
18,584 (2.64/day)
System Name AlderLake
Hmm I always had mine set to "Optimal Performance", even when I was benchmarking.
985 (0.21/day)
Ireland
On optimal there will be clock drops more often due to fps spike? When on adaptive not?
On optimal plan it will stay at least on base clocks, on adaptable they will drop down.
63 (0.02/day)
Mouse G703 Logitech
Thanks, that seems sensible. Seeing as I am not too concerned about GPU power usage I can conclude from this that "prefer maximum performance" is the most certain way to get proper/max performance. However in many cases
adaptive will be just as good with the added benefit of saving power
My only reason for keeping max power when gaming is, I'm not 100% sure if the adaptive setting is quick enough to almost instantly ramp up the power everytime? Seems clear it is most of the time though. But if a sudden heavy action/visual screen comes in after sometime not moving much or being in a simple menu I prefer not to take the chance (at the cost of power). One other thing that solidified this opinion is that a small amount of very graphics demanding games already have the default setting on prefer maximum performance in the NVCP. This is certain for Doom 2016.
So I will continue what I've been doing. That is, IMO it's just that bit better (possibly in extreme cases) to set prefer max performance in games. Well, modern resource hogging games at least.
As for everything else I have my global setting to Optimal so only gaming likely uses full power. I've done this since optimal was introduced and had zero problems. I reckon if it ain't broke, no point messing with it.
P.S. Even though there have been helpful replies in this thread, I get the feeling that no one really knows, or I should say agrees, on what exactly optimal is!
For me it's a non issue, but I sure wish NV would do a better job of passing on relevant info - like GPU power settings, that's pretty relevant don't you think?
985 (0.21/day)
Ireland
Hey. So why during fps drop in GTAV i had clock spike for just one second? I have optimal setting in nvidia panel. It is because optimal? Maybe i must change to adaptive then?
I'd try maxinum perfirmance option instead.
44,274 (6.80/day)
Adaptive is power when demands arrise, max performance should run the card at a constant rate.
1,400 (0.29/day)
78°55' N, 11°56' E
System Name -aLiEn beaTs-
Processor Intel i7 11700kf @ 5.055Ghz
Motherboard MSI Z490 Unify
Cooling Corsair H115i Pro RGB
Memory G.skill Royal Silver 4400 cl17 @ 4403mhz
Video Card(s) Zotac GTX 980TI AMP!Omega Factory OC 1418MHz
Storage Intel SSD 330, Crucial SSD MX300 & MX500
Display(s) Samsung C24FG73 144HZ
Case CoolerMaster HAF 932 USB3.0
Audio Device(s) X-Fi Titanium HD @ 2.1 Bose acoustimass 5
Power Supply CoolerMaster 850W v2 gold atx 2.52
Mouse Razer viper 8k
Keyboard Logitech G19s
Software Windows 11 Pro 21h2 64Bit
Benchmark Scores ► ♪♫♪♩♬♫♪♭
I noticed optimal can lower full 3d p0 state bellow base freq., I keep optimal in global and in games perfer max perf. Imo the safest bet to run the game smooth.
Status
