what bluetooth adapter to use for all uses... latest?
797 (0.16/day)
UT,US
System Name Asrock 2012
Processor FX 8350 4.2Ghz no turbo
Motherboard ASRock 970 PRO3 AM3+
Cooling Corsair H70 for CPU
Memory 32GB DDR3 1960Mhz
Video Card(s) NVIDIA 1080 with stock fan
Storage 1TB GIGABYTE SSD NVME PCIE 2.0 + Samsung SSD Evo 850 250GB with Ubuntu + Samsung SSD 860 500GB win7
Display(s) LG HDR 31.5"
Case Big Black Tower
Audio Device(s) Realtek audio + Audigy 2 ZS platinum
Power Supply CORSAIR RM850X
Mouse microsoft intellimouse usb to ps/2
Keyboard Logitech
Benchmark Scores +
Hi I have an old adapter that doesn't work well on windows 7, I want to use the best adapter of bluetooth so which version should I get 5.0 5.1 or 5.2? it's so I connect a ps4 wireless controller to play Grid.
If I need windows 10 I could swap the OS at boot but I got my games on windows 7.
18,450 (2.47/day)
Best? I doubt there's such a thing when it comes to Bluetooth.
The only thing really to be concerned with and it doesn't really seem to apply to Windows, is audio codec support.
Pick up whatever you can get locally, as you're not going to know what chipset is in 90% of the dongles, as the manufacturers usually don't specify it.
If you need long range, look for a dongle that supports up to 100m. I doubt you'll find anything with longer range. Normal range is 10m.
The minor versions most likely don't apply either, but you might as well go with 5.2.
The PS4 controllers are only 2.1, but will obviously work with 5.x. The PS5 supports 5.1.
13,942 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
IMO, if buying new, you should always go with the latest version when possible. This [hopefully] ensures the best "future proofing".
"In theory", BT5.2 is backwards compatible to BT4 devices. But there are some newer features/enhancements that don't work with BT4.2 devices.
To me, the most important thing TLS said is,
I agree totally. This also typically means (to me) to ensure the BT adapter is an external device (like a USB dongle) - that is, something that sticks out and away from the case, and not a device that installs totally inside a metal (which provides excellent RF shielding - not good in this scenario) PC case. External RF devices (BT, wifi adapters, RF mice, etc.) ensure the antenna(s) used in that device are on the outside of the PC's metal case.
Internal devices are great for BT devices that will be used in very close proximity to the computer - such as keyboards and mice. But as soon as distance is needed, the external antenna of the dongle is desired.
Speaking of "in theory", I note the specs for BT5.x claim the range is 400 meters! Yeah right. Keep reading and it claims (I'm paraphrasing) the effective range is 200 meters. Yeah right, again. Then it claims the range is "40 meters indoors". That's more like it, if this is in a very long hallway, and there are no barriers (walls) between the two BT devices.
And while they use different bands and technologies, BT still operates in the very popular, widely used 2.4GHz RF band. This means it is possible other devices could cause interference, which may also affect usable range.
So if you follow the TLS's advice and get an adapter to that supports a range of 100m (328 feet), it should "in theory" easily support the more likely distances (and crowded 2.4GHz RF environments) normally used in homes - which is probably less than 50 feet.
Of course, "in theory" and "real world" don't always jive. So make sure wherever you buy from has a return policy.
44,267 (6.80/day)
Go with a well known reputable company such as tp-link/trendnet/netgear/jvc/pioneer/samsung/sony/logitech/microsoft/creativelabs/turtlebeach/club3d...
Many more out there. Not the cheapest transmitter either
18,450 (2.47/day)
Having had a quick look, it seems like Windows 10 supports basic AptX audio, so in case you have some headphones or speaker(s) that supports AptX, you might want to get a dongle with a Qualcomm, previously CSR, chip inside. However, CSR chips won't support recent Bluetooth standards past 4.x.
One other options is to get one of the many generic Wi-Fi cards that come with Bluetooth, as most of them have an Intel card onboard that supports Bluetooth 5.x. Just make sure you check what you get before buying and this would obviously be a more expensive route, as you're also paying for a Wi-Fi card. On the plus side, these cards have pretty decent antennas compared to the built in ones in most dongles.
6,660 (1.58/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
This is true but not to a great extent. I have several pcie WiFi/BT 4/5xx cards that are intel-based and only cost me about $30 each (the most recent being an Asus model)....whereas dongles can be found from $8-20 if you look at the bottom-barrel garbaggio.... but I would not recommend that route.
Prior to getting the cards, I tried & returned multiple dongles (15 or 20 different brands/prices) simply because they either did not work at all, would not maintain a consistent connection, and/or had very poor range, so thats what led me to buy the cards..
And NO, I have neva, eva found either a dongle nor a card that would get anywhere near 400ft range-wise.... 80-100ft yes, but not much beyond that :)
7,480 (1.04/day)
Video Card(s) Sapphire PURE AMD Radeon™ RX 9070 Gaming OC 16GB | Intel® Iris® Xe Graphics
Personally when I use my PS4 controller on my computer I use the official Sony Playstation 4 Dualshock USB wireless adapter so I don't need any third party programs like DS4 and so on.
797 (0.16/day)
UT,US
Keyboard Logitech
Benchmark Scores +
what if the adapter is not in that list of brands, how do I tell the brand is reputable by looking at their website layout or customer service number is posted?
18,584 (2.64/day)
System Name AlderLake
18,450 (2.47/day)
If it's only for the controller, I would follow the advice above and get the official Sony dongle, it'll cause fewer potential problems.
As for reputable brands, I wouldn't worry too much about it, as these things either work or don't work, since all of them are going to be based on reference code and software from the chip makers.
I still use the older Asus USB-BT400 myself.
Should cost no more than $15
The BT500 is Realtek based with a metal PIFA antenna.
Doesn't really make sense paying twice or three times the price for that compared to something else, just for the Asus brand name.
At least the one you have, has a Broadcom chip in it, although it relies on an integrated PCB antenna.
If the manufacturers were more honest about what hardware they put inside their products, it would be easier to chose well supported hardware, rather than having to guess what will get driver updates and what is less likely to see updates.
797 (0.16/day)
UT,US
Keyboard Logitech
Benchmark Scores +
are you friking kiding me? all the sony bluetooth average 100$!! I make like 300$ a month and lately I been getting mental court fees every 2-3 days... damn I was expecting something like 25$ I guess I'll get a friend that has a ps4 I can borrow ja!
797 (0.16/day)
UT,US
Keyboard Logitech
Benchmark Scores +
how much did you pay for it? those cost a lot on ebay
2,207 (0.76/day)
If your using windows 7 then the best PCIe adaptor is Intel 8265 "Bluetooth 4.2". There's nothing better & is the last to support Windows 7 via the PCIe slot.
EDIT: Latest version of bluetooth is 5.2, but you will need windows 10. (Intel AX210) PCIe.
7,480 (1.04/day)
Uh I purchased it sometime ago, but I believe maybe about 30USD something. I purchased it in Denmark.
1,264 (0.20/day)
Hampton Roads
Processor Xeon x5650
Motherboard SABERTOOTH X58
Cooling Fans
Memory 24 GB Kingston HyperX 1600
Video Card(s) GTX 1060 3GB
Storage small ssd
Display(s) Dell 2001F, BenQ short throw
Case Lian Li
Power Supply X750
Software Mint 19.3, Win 10
Benchmark Scores not so fast...
Posted, mainly, to sub to the thread, as I'm interested in the topic. All of my controllers are wired, and the idea of wireless controllers for my PC sounds like a better solution.
797 (0.16/day)
UT,US
Keyboard Logitech
Benchmark Scores +
30USD? da fuck I see them for 80-120$ on ebay, did market raise the price?
212 (0.06/day)
ID_SUB
System Name Asus X450JB
Processor Intel Core i7-4720HQ
Motherboard Asus
Memory 2x 4GiB
Video Card(s) nVidia GT940M
Storage 2x 1TB
What are you buying? lol. Most BT5.2 dongle are around $20, any more than that you're probably paying the brand tax or actually buying something else.
$120? Did you somehow pick one attached to WiFi card?
7,480 (1.04/day)
Issue with generic once is you need to use a program like xpadder or something to get all the buttons mapped I don't using the official USB adapter.
It looks like to be discontinued.
I got mine from Elgiganten in Denmark: https://www.elgiganten.dk/product/g...ps4-dualshock-4-tradlos-usb-adapter/PS4WLADPT
