what does microsoft basic display adapter means
ciment
4 (0.00/day)
does it mean that this bios can solve some issue realted to incompatibility of a card with basic display drivers ?
631 (0.54/day)
Processor AMD Ryzen 7 5800X3D
Cooling Custom Watercooling
Display(s) Samsung G7 27" x2
Mouse Logitech G903
Keyboard Steelseries Apex Pro
That would be the driver Windows uses when it can't find the actual driver for your gpu. Normally that is fixed by downloading and installing the proper driver from the manufacturer.
8,294 (5.23/day)
São Paulo, Brazil
Cooling Pichau Lunara ARGB 360 + Honeywell PTM7950
Memory 32 GB G.Skill Trident Z5 RGB @ 7600 MT/s
Video Card(s) Palit GameRock GeForce RTX 5090 32 GB
Storage 500 GB WD Black SN750 + 4x 300 GB WD VelociRaptor WD3000HLFS HDDs
Display(s) 55-inch LG G3 OLED
Case Cooler Master MasterFrame 700 benchtable
Mouse Microsoft Classic IntelliMouse
Software Windows 10 Pro 22H2
Is this the same card that you posted about in April of 2023? If so, I wouldn't get your hopes up. I just read that thread on your post history, and that looks like a GPU with hardware damage.
ciment
4 (0.00/day)
i grabbed it again . its memories are samsung k4G80325Fb. any bios i flashed on it that was for these memories did a thing with some vertical stripes at startup. this was only with a cold boot. after a bunch of restarts posted correctly and performed correctly which is why it bothers me . its very possible that this gpu was created exactly for mining but it wont be long until it reaches flashing limit and this all will be over. Now i flashed a bios for k4G80325Fc types of mem , enabled csm , disabled secure boot . did another cold boot and posted correctly . no stripes yet but im very pessimistic. thanks for the replies
another answer that i found was that this copy of bios has basic display in its description because at the time it was uploaded with gpu-z , it only had the basic driver installed most probably meaning that an official driver might not work with it since the purpose of the gpu is to mine or got damaged from being mined with
Solaris17
Super Dainty Moderator
27,605 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Video Card(s) MSI SUPRIM Liquid 5090
Audio Device(s) Moondrop S8's on chitt Gunnr
Keyboard Wooting 80 HE White, Gateron Jades
VR HMD Quest 3
Only the person that wrote it would know. That description is not from GPUZ it is a user field you can write in before pressing submit. There is nothing official about those descriptions.
44,274 (6.80/day)
Its a generic vesa compatible driver by ms which is just to get it working, it is not optimized for everything.
