- May 8, 2023
- 65 (0.09/day)
under load, or depending on the voltage spike, I see drops in the PCIe +12v Voltage readings on both HWInfo and GPU-Z softwares. the drops I see are still in ATX spec and if I'm not mistaken, higher load on the GPU can draw more power from the PSU and generate drops in the PCIe/12v rail, but what is the expected behavior here?
at 0.6 and 0.7v on the Core GPU Voltage, I see 12.0v on the PCIe reading
once I hit 0.8 and 0.9v, the PCIe drops to 11.9
and if I hit 1v, the PCIe drops to 11.87/11.88
under normal gaming load, I'm usually seeing 0.7-0.9v readings, although sometimes it might quickly spike to 1.08v; furthermore, if I run Heaven Benchmark at full 100% GPU load (around 230-250w iirc for RTX 3070), my PCIe voltage drops to ~11.79
is this normal behavior for the PCIe and Core Voltages? I know higher loads can create a drop in the PCIe, but are these specific voltage readings okay? my PSU is a Phanteks Revolt 1000w so obviously it can handle the 3070, I just need to know if something seems faulty here
