What is MCP & SPP?
457 (0.07/day)
Irvine, CA
System Name My3yrOldBaby
Processor Intel C2Q Q6600 G0 2.4GHz (3.6 Ghz @ 1.400V)
Motherboard eVGA 790 FTW (Analogue) 132-YW-E179-A1
Cooling Thermalright Ultra-120 eXtreme (Push+Pull: Silverstone 120mm)
Memory 8GB G.Skill DDR3 2x4GB 1866 (running 1600) + 2GB Crucial Ballistix DDR3 1x2GB 1333 (running 1600)
Video Card(s) eVGA 8800GTX 768MB
Storage (2) WD Raptor 150GB SATA [RAID 0], (4) Seagate Barracuda 320GB SATA [RAID 0+1]
Display(s) Acer 20" - AL2017, Acer 22"W - AL2216WBD
Case Thermaltake Armor w/ 25cm Fan & Extra Front iCage
Audio Device(s) OnBoard
Power Supply Silverstone 1000W - ST1000
Software Windows XP Pro x64
I've seen some people use these acronyms for controllers on their boards.
Am I right that MCP=Southbridge & SPP=Northbridge? Just on nVidia systems?
Btw, we should get a computer acronyms thread started, including all the technical terms like PCB, CPU, MOSFET, SB, NB, etc... If anyone else thinks this is a good idea I'll start one right away.
panchoman
Sold my stars!
9,595 (1.48/day)
Processor Amd Athlon X2 4600+ Windsor(90nm) EE(65W) @2.9-3.0 @1.45
Motherboard Biostar Tforce [Nvidia] 550
Cooling Thermaltake Blue Orb-- bunch of other fans here and there....
Memory 2 gigs (2x1gb) of patriot ddr2 800 @ 4-4-4-12-2t
Video Card(s) Sapphire X1950pro Pci-E x16 @stock@stock on stock
Storage Seagate 7200.11 250gb Drive, WD raptors (30/40) in Raid 0
Display(s) ANCIENT 15" sony lcd, bought it when it was like 500 bucks
Case Apevia X-plorer blue/black
Audio Device(s) Onboard- Why get an sound card when you can hum??
Power Supply Antec NeoHe 550-manufactured by seasonic -replacement to the discontinued smart power series
Software Windows XP pro SP2 -- vista is still crap
mch is the northbridge. idk about southbridge. but mcp is i believe multicore processor, its for the chipset, you need an mcp chipset to run dual/quad core cpu's, imma take a wild guess at spp, single ? processor
457 (0.07/day)
Irvine, CA
Ok, I've done some research, and this diagram says it all:
This is the architecture for a 680i system.
northbridge is primary, through which everything else goes, correlating to the SPP
southbridge is secondary, feeding into northbridge, correlating to MCP.
So, I was initially correct, NB=SPP, SB=MCP.
2,817 (0.43/day)
louisiana
Processor Intel Core i5-12400F - Core i5 12th Gen Alder Lake 6-Core 2.5 GHz LGA 1700 65W
Motherboard GIGABYTE B760M--DS3H LGA 1700 DDR4
Cooling CPU - Thermalright Assassin King 120 SE / Case - cooler master 120mm rear case fan (Air cooling)
Memory CORSAIR Vengeance LPX 32GB (2 x 16GB) 288-Pin PC RAM DDR4 3200 (PC4 25600)
Video Card(s) GTX1060 6GB
Storage Samsung 1 TB 870 EVO SSD Main Drive / Samsung 500 GB 870 EVO SSD Backup Drive
Display(s) ASUS 23" LED Monitor
Case COOLER MASTER Centurion 5 (silver & black)
Power Supply CORSAIR RM-750X 750W Modular ATX
Software Windows 11 Pro 64bit Edition
m = master
s = slave
panchoman
Sold my stars!
9,595 (1.48/day)
so his southbridge is the master???
i'm doing some googling, and the first thing that came up was this exact thread lmao.
mcp could stand for multichip package...
ran into something interesting... http://www.sixsigmaservices.com/default.asp they have a pic of an intel chip on there, which means they have something to do with em, and they work with multichip packages... could that be an intel mcp chip??
six sigma is one of those companies that manufacture all kinds of stuff that you use and you dont even realize it, they build all kinds of cpu type things sorta cause when i googled six sigma intel loads of weird things came up..
Athlon2K15
HyperVtX™
7,909 (1.16/day)
O-H-I-O
Processor Intel Core i9 11900K
Motherboard MSI Z590 Carbon EK X
Cooling Custom Water
Memory Team DDR4 4000MHz
Video Card(s) ASUS TUF RTX 3080 OC
Storage WD WN850 1TB
Display(s) 43" LG NanoCell 4K 120Hz
Power Supply Asus Thor 1200w
Mouse Asus Strix Evolve
Keyboard Asus Strix Claymore
no...no...no MCP is media communications processor & SPP means System Platform Processor...so basically one controls usb,hard drives,and other "media"..and one controls the busses on the motherboard
