What is the ideal low-cost GPU for i3-10100 and 250W PSU?
alieren3453
4 (0.00/day)
Hello, I am a budget user. Recently I purchased a PC which has i3-10100 8GB RAM 250W PSU H510M-H Motherboard and 256 GB SSD for 300$. I am planning to play Valorant, HOI4 and maybe The Forest at low settings. Since 1 dollar is equivalent of 14 Turkish Liras small changes in prices can make big changes. For example GT 1030 GDDR5 version is 1800 Turkish Liras but 1050ti is 3700 liras. So I purchased this PC for 5200 TL(300USD) and as you can see I don't have much money or much expectations. What you can recommend me for this PC to handle these games. I'm running on single channel ram. So iGPU performance is low. Does it make more sense to use iGPU and double channel ram to boost iGPU performance? What you recommend?
1,843 (0.59/day)
BGD
System Name Minotaur
Processor Intel I9 7940X
Motherboard Asus Strix Rog Gaming E X299
Cooling BeQuiet/ double-Fan
Memory 192Gb of RAM DDR4 2400Mhz
Video Card(s) 1)RX 6900XT BIOSTAR 16Gb***2)MATROX M9120LP
Storage 2 x ssd-Kingston 240Gb A400 + HDD 500Gb+2xSSD Kinston 480Gb+5Tb Seagate+512Gb NVME SGI
Case NZXT H5 Flow
Mouse Asus TUF-GAMING M3
VR HMD Oculus Rift DK2
Software Win 11
Benchmark Scores Fire Strike=23905,Cinebench R15=3167,Cinebench R20=7490.Passmark=30689,Geekbench4=32885
First of all welcome on TechPowerUp forum.......now first considering your IGPU question,YES it does make sense to have dual channel ram and also more ram because your IGPU will use certain amount of RAM but also do not expect miracles....now the GPU's atm are still expensive better then few months before but still not perfect if you are really short on money then maybe it's better to buy used GPU's maybe something in range of RX 470/570 or RX 480/580 4g version are cheaper and it will still do the job or if you prefer Nvidia you can maybe look for some used GTX 970 even cheaper GTX 960 is still Ok or a bit better but more expensive GTX 1060.......all those GPU's should be in range around 110-250 € but everyday they getting cheaper.......new GPU's are much more expensive and I can not suggest you to get for example GT 1030 because honestly it's not worth that money performance vise........Also I can't be sure of exact GPU's prices in Turkey but if you saying that GTX 1050 TI cost 3700 liras(230€) that still expensive and if you can buy any of GPU's that I mention above for that money or close to that it will be far better choice for you.......GL
P.S. IF your PSU is 250W then you can't use probably ANY of those cards I mention above...then yeah GT 1030 or some card that do not use more then 100W make sense or you can get some better PSU and get more powerful GPU....
9,828 (3.41/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
The best low end card is actually the 6500XT. Much faster than a 16 series card or anything older from AMD.
That is just over $250 US but if the price is right a 6600/3070 will be a much better choice.
alieren3453
4 (0.00/day)
First of all welcome on TechPowerUp forum.......now first considering your IGPU question,YES it does make sense to have dual channel ram and also more ram because your IGPU will use certain amount of RAM but also do not expect miracles....now the GPU's atm are still expensive better then few months before but still not perfect if you are really short on money then maybe it's better to buy used GPU's maybe something in range of RX 470/570 or RX 480/580 4g version are cheaper and it will still do the job or if you prefer Nvidia you can maybe look for some used GTX 970 even cheaper GTX 960 is still Ok or a bit better but more expensive GTX 1060.......all those GPU's should be in range around 110-250 € but everyday they getting cheaper.......new GPU's are much more expensive and I can not suggest you to get for example GT 1030 because honestly it's not worth that money performance vise........Also I can't be sure of exact GPU's prices in Turkey but if you saying that GTX 1050 TI cost 3700 liras 230€) that still expensive and if you can buy any of GPU's that I mention above for that money or close to that it will be far better choice for you.......GL
1050 TI costs 230€ because unfortunately taxes are too high bro :(
1,843 (0.59/day)
BGD
Case NZXT H5 Flow
Software Win 11
This going to cost more in Turkey.........also do not forget that 6500XT is PCIe Gen4 8x so he will be limited on PCIe Gen 3 8x which can cripple his performance in certain games......
Deleted member 202104
In your situation, I'd add another 8GB (not for the dual channel, but to achieve 16GB), and the go with the 1030 GDDR5. It fits your price, power supply limits, and should provide a good experience with the games you mentioned. Just don't expect benchmark breaking performance.
Oh, and also, welcome to TPU. :)
1,843 (0.59/day)
BGD
Case NZXT H5 Flow
Software Win 11
Yeah I assume is difficult situation there...well ain't easy to get cheap GPU's anywhere anymore but hey at least finally it's getting better.......Also srry IF your PSU is 250W then you can't use probably ANY of those cards I mention above...then yeah GT 1030 or some card that do not use more then 100W make sense or you can get some better PSU and get more powerful GPU....
562 (0.27/day)
Processor i9-9900K @ 5.1GHz (H2O Cooled)
Motherboard Gigabyte Z390 Aorus Master
Cooling CPU = EK Velocity / GPU = EK Vector
Memory 32GB - G-Skill Trident Z RGB @ 3200MHz
Video Card(s) AMD RX 6900 XT (H2O Cooled)
Storage Samsung 860 EVO - 970 EVO - 870 QVO
Display(s) Samsung QN90A 50" 4K TV & LG 20" 1600x900
Case Lian Li O11-D
Audio Device(s) Presonus Studio 192
Power Supply Seasonic Prime Ultra Titanium 850W
Mouse Logitech MX Anywhere 2S
Keyboard Matias RGB Backlit Keyboard
Software Windows 10 & macOS (Hackintosh)
User doesn't have the means to upgrade PSU, which would mean they cannot use any "decent" (subjective keyword there) dGPU in my opinion. absolutely needs to be a dGPU that requires no additional aux power so it never pulls more than 75W that it can get from PCIe slot
you both recommended card(s) that requires more PSU power than what they have! :banghead: OP should avoid these unless they upgrade PSU also!
recommended PSU, 200W, requires no aux power cables, this is a good suggestion! as far as it will work and nothing explodes.....performance wise though, "good" is subjective. I'd assume better than the iGPU at least which is what the OP is after.
actually, heres some proof it is better
alieren3453
4 (0.00/day)
I'm not aiming to play games like Apex Legends or Fortnite. Just CS:GO, Valorant and Rocket League is enough for me. (at 1080 60fps). Would it be senseful to use 1030 with no ram upgrade on a 240w psu? Currently Valorant performance sucks. I just want to improve it.
Which is why I recommended it. With the constraints listed in the OP, this is about a much as you're going to get. As your link mentioned, you'll see about twice the performance from the 1030 over the iGPU.
Yes, if you can only do one of the upgrades, the GPU first.
I don't play Valorant, but here's something to look at. It says 'up to 151 fps at 1080p Ultra'
alieren3453
4 (0.00/day)
Ok I think I will buy GT 1030 GDDR5, I heard that DDR4 version sucks. Thanks to all you guys for your help! I'm so grateful. Thx a lot.
1,861 (0.53/day)
North Dakota
System Name Office
Processor Core i7 10700K
Motherboard Gigabyte Z590 Aourus Ultra
Video Card(s) Intel ARC A750
Display(s) Dell S2719DGF
Case Fractal Define 7 Compact
Power Supply EVGA 550 G3
Mouse Logitech M705 Marthon
Keyboard Logitech G410
Software Windows 10 Pro 22H2
Other cards to consider, listed in ascending performance:
RX 550
GTX 750 (driver support discontinued)
RX 460
RX 560
GTX 950 LP (if you can find one)
All are 75W or less, and will roundly thrash a GT 1030.
835 (0.51/day)
In 1 month or so, we are supposedly going to have the launch of Radeon RX 6400 (4GB, 53W) it should be at least 10% faster than a 1050ti in your PCI-express 3 setup and the rumoured SRP is $129 (i wouldn't hold my breath, probably $159) but since 6500XT is selling at SRP or +10% more, this will probably range between 1.800-2.900 T.L. depending the scenario (probably 2.900 T.L...)
5,471 (3.65/day)
Colorado, U.S.A.
Software Windows 11 Home
44,274 (6.80/day)
You are shooting yourself in the foot with that card, you have a better chance with a 5000 or 6000 series RX of not being a fake like a GTX 1000 series today.
1,065 (0.28/day)
System Name loon v4.0
Processor i7-11700K
Motherboard asus Z590TUF+wifi
Cooling Custom Loop
Memory ballistix 3600 cl16
Video Card(s) eVga 3060 xc
Storage WD sn570 1tb(nvme) SanDisk ultra 2tb(sata)
Display(s) cheap 1080&4K 60hz
Case Roswell Stryker
Power Supply eVGA supernova 750 G6
Mouse eats cheese
Keyboard warrior!
Benchmark Scores https://www.3dmark.com/spy/21765182 https://www.3dmark.com/pr/1114767
idk, looks legit - flipkart still big in turkey? (EDIT) nevermind, wrong country fc is india
just stay off fleabay. :fear:
44,274 (6.80/day)
eBay has a 15-30 day return policy. I challenged a person for misrepresenting a Ry7 5800 as a 5800X and instead of paying $362 I paid $262 after I had tested it and verified it is working (got $100 back)
