What's a good test for a thermal glue?
296 (0.53/day)
CincinnatiOH!
I was given some, but I've never used it before so I'm looking for suggestions on good ways to test it - obviously, without my computer being the guinea pig! ;)
For now, I just need to have a way to evaluate it. This is the glue I have.
xu^
1,161 (0.18/day)
Lancs,UK
System Name Mr_average ( hoping 1 day to upgrade to Mr_above_average )
Processor AMD Ryzen 7 7700x
Motherboard Asrock B650 Steel Legend Wi-fi
Cooling Arctic Freezer III 240mm AIO RGB - White | 4 Lian Li ST120mm case fans - White
Memory 32gb Corsair Vengeance RGB 2x16gb 6000mhz DDR5 - White
Video Card(s) Asus Dual GeForce RTX 4070 12GB OC - White
Storage 1tb WD Black Nvme | 2tb WD Black Nvme | 4tb Samsung SSD | 2tb WD Blue SSD| 1tb Crucial P3 Nvme
Display(s) D1: LG Ultragear GL850-B 27" 1440p 144hz | D2: Asus Tuf - VG249 24" 1080p 144hz
Case Lian Li Lancool 2 Mesh RGB - White
Audio Device(s) Creative Gigaworks T20 Series II | Steelseries Arctis 3 Headset
Power Supply Corsair TX650M Semi Modular 80+ Gold
Mouse Razer Basilisk V3
Keyboard Razer Huntsman V2
is thermal glue something different from thermal paste ? kinda confused here, as never heard it called that before :ohwell:
296 (0.53/day)
CincinnatiOH!
Yes, it's different. It has thermal conductivity as well as strong adhesion.
501 (0.10/day)
Quodam loco Albanianae
System Name The Dark side of the room
Processor AMD Ryzen 9 5900X
Motherboard MSI MEG X570 Unify
Cooling Custom loop watercooling (Bykski CPU-XPR-POM-M-V2, Alphacool Eisblock GPX, Freezemod PU-PWM5B18W)
Memory GSkill Ripjaws V DDR4 3600 CL16 (4 x 16GB)
Video Card(s) XFX Speedster QICK 319 Radeon RX 6700 XT
Storage 1 x Kingston KC3000 1024GB (boot drive) + 2 x Kingston NV2 2TB (games & storage)
Display(s) LG 34WP65C Ultrawide 3440x1440 @ 160Hz freesync premium
Case Thermaltake Core P90 TG (slightly modded)
Audio Device(s) onboard Realtek® ALC1220 with Logitech Z906
Power Supply MSI MAG A850GF 80 Plus Gold
Mouse Roccat Burst Pro black
Keyboard Sharkoon Skiller SGK60 (with brown Kalih switches)
Software Windows 11 pro
Benchmark Scores It's a form of exhibitionism...;-), but fun in a way But showing off is triggering.............
https://en.wikipedia.org/wiki/Thermal_adhesive#:~:text=Thermal adhesive is a type,no other mounting mechanisms available.
Never used it myself, but do recall that Arctic in the MX2 period (over a decade ago) had some 2-component ceramic thermal glue to attach small heatsinks to induvidual chips/components like VRAM and VRM's.
But never read any in deep reviews regarding cooling performance or thermal conductive benefits over other solutions. It was just for a one time apllication and don't touch anymore for the lifespan of the component you use it on.
Removing it is a pain in the @ss, like you can read in this thread from twenty years ago: https://forums.overclockersclub.com...lver-thermal-adhesive-removal-is-it-possible/
I would leave it alone and put it on display as an elusive cooling solution monstrosity from the past :D , things have evolved since then ;).
1,842 (0.33/day)
Azalea City
System Name Test Bench #3
Processor Ryzen 5 8600G delidded, +200PBO -30CO
Motherboard B650M-HDV M.2
Cooling Water, liquid metal
Memory TRIDENT Z5 @8400CL36
Video Card(s) 760M @3300MHz
Storage Samsung PM981
Display(s) MAG401QR
Case Open Frame
Audio Device(s) Logitech Z623
Power Supply EVGA P5
Mouse Cooler Master MM710
Keyboard Huntsman Elite
Software 10 Pro
Benchmark Scores https://hwbot.org/user/luke
It depends on your needs. Like do you want it permanently attached or something you can remove with slight effort without destroying the chip?
I've used the old stuff you had to mix but nowadays I buy the cheap tube of stuff.
Easycargo Thermal Glue, High... https://www.amazon.com/dp/B07HCDRL7W?ref=ppx_pop_mob_ap_share
Keeps the stuff on way better than thermal tape but I can easily remove it and scrape it off the IC when I'm done. The only problem with this particular product is that once the tube is opened, the whole tube begins to cure even when you put the lid back on, giving you just a few weeks of usage before it's ruined and you need to buy more.
501 (0.10/day)
Edit,
@TPCEA , why not send it to Igor's Lab. Maybe he wants to test it and put the results in his database, I quote from this article:
In the coming tasks, I will continue to refine the database, in particular through detailed analyses of very thin layer thicknesses below 30 µm. In addition, long-term assessments of the stability of pastes and pads under thermal stress will continue to be carried out. Other focal points are the expansion of material analyses, the recording of new surface types and the integration of community feedback. The aim is to further expand the database as one of the most well-founded sources for thermally conductive materials and to provide users with an even more precise basis for decision-making. Somehow the whole project is almost mutating into something like a never-ending life’s work, which I’m sure my son will be happy to continue. Let’s see…
2,318 (4.41/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) 1080P 144hz
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Just ideas!!
Use the paste to glue 2 coins together. Once it cures, set one side on a low watt incandescent light bulb and hold it there with your finger and see how long it takes to warm up the coin. If it seems to take a long time, the glue is acting as an insulator, I wouldn't use it. 2 quarters, test cost total 50 cent. :)
(Or something similar to this)
AsRock
TPU addict
19,250 (2.95/day)
UK\USA
Cooling D15
I have some in the fridge by arctic silver, it great stuff more so years ago when vram chips were not covered with any thing. Not used it for years as typically they are these days. Used it on AV's in the past to for those DSP chips and other hot spots.
296 (0.53/day)
CincinnatiOH!
Fo
Just ideas!!
I like that idea - simple but effective!
1,842 (0.33/day)
Azalea City
Display(s) MAG401QR
Case Open Frame
Software 10 Pro
Fo
I just bought some Gennel thermal bulk grease last week. They seem to be dumping a lot of cheap product on Amazon. I'm curious if it is good.
44,267 (6.80/day)
Its thermal expoxy, some are permenant, like arctic silver thermal epoxy, i used to mix as5 with the epoxy so i could remove heatsinks with little force
