Whats the proper name for a VGA switch, hub, double adapter or whatever?
Joshmcmillan
892 (0.13/day)
Australia, NSW,Mid North Coast.
System Name Commander
Processor Intel i3 540 3.06Ghz
Motherboard Gigabyte GA-H55-UD3H
Cooling 4x 80mm Case Fans, Zalman ZM-MFC1 Fan Controller, Stock CPU Cooler
Memory 4GB DDR3 1333Mhz (2x 2GB) - Kingston
Video Card(s) HIS ATi Radeon HD3850 256mb DDR3
Storage 640GB Western Digital Caviar Black
Display(s) 22" BenQ FP22W LCD, 700:1, 5ms, 16:10
Case Don't know exactly, metal, built on LED's.
Audio Device(s) Integrated - Altec Lansing 5.1 Speakers (6.5" Sub)
Power Supply Antec True 550W, 24 AMP on 12v rail
Software Vista Home Premium 64bit - AVG - Spybot
I am buying a VGA cable for my Xbox 360 so I can play it in HD on my computer monitor. But then I thought It would suck changing the cable around all the time depending on whether I was using my computer or my 360 so I wanted to buy a double adapter for VGA. Then I went on ebay and searched for VGA switch, VGA hub and VGA double adapter and nothing comes up in Australia so I thought there must be another name for it because I know it must exist. So my question is what is the proper name for something that allows you to plug ur monitor into a computer and something els at the same time, but only use one at a time.
Thanks in advance,
Josh
Its like a KVM switch. I think you can find them at radio shack and such. Offers you a split into different tvs, monitors, etc.
