WHEA Uncorrectable Error
820 (0.14/day)
Bristol-U.K
Processor Intel i5-12400F
Motherboard Asus Prime H610M-A WIFI D4
Memory CORSAIR VENGENCE 16GB LPX DDR4 3200MHZ
Video Card(s) RTX 4070
Storage 1TB SSD
Display(s) MSi Optix 27" 1440p 144hz + MSI OPTIX 27" 1440P 165HZ
Case COOLER MASTER MB320L ARGB
Power Supply Corsair cv650
Mouse Logitech G203
Keyboard Corsair Strafe RGB MX Silent
Software Windows 11 PRO
been having this error lately. happend 8 times in the last 3 months.
its purely random.mainly when i game.
believe its related to the cpu overclock.maybe needs more voltage?
what do you all think.
Regeneration
NGOHQ.COM
3,151 (0.44/day)
WHEA errors on X58 are related to overclocking.
Internal parity error = insufficient CPU voltage
Cache Hierarchy Error = insufficient QPI/VTT voltage
Increase vcore and run Linpack Xtreme (the bootable version is better) for a few hours.
820 (0.14/day)
Bristol-U.K
Storage 1TB SSD
Mouse Logitech G203
Internal parity error = insufficent CPU voltage
Cache Hierarchy Error = insufficent QPI/VTT voltage
Increase vcore and run Linpack Xtreme for a few hours.
thanks
whats the max that i should increase it by
hat
Enthusiast
21,754 (3.23/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Just take small steps until you get the results you want. If you're at 1.30v now, try 1.325v. I had an i7 920 I could get to run stable at 4GHz once, but I don't remember the voltage... I just remember it was HOT. You have a 32nm chip though (the i7 920 is 45nm) so you may have better results.
Regeneration
NGOHQ.COM
3,151 (0.44/day)
0.01875v for instant crash
0.01250v when you're almost stable
I wouldn't go over 1.33v on ASUS P6T with LLC on air cooling for 24/7.
820 (0.14/day)
Bristol-U.K
Storage 1TB SSD
Mouse Logitech G203
i just ran a stress test twice.
both times came back with a hardware failure detected.thus stopping the test.
vcore is at 1.33v
Deleted member 50521
Probably CPU degredation over the years. Just need more voltage or back down on overclocking a bit.
Regeneration
NGOHQ.COM
3,151 (0.44/day)
Or never been stable in the first place... failures shouldn't occur that fast.
820 (0.14/day)
Bristol-U.K
Storage 1TB SSD
Mouse Logitech G203
well i have tested cinebench and occt as we speak.
has always passed.
Regeneration
NGOHQ.COM
3,151 (0.44/day)
Cinebench is a benchmark and shouldn't be used to test OC stability.
Best tools to test stability on X58:
CPU stability = Linpack Xtreme (bootable version)
QPI/DRAM = Prime95 v26.6 large FFTs
QPI/IOH = Prime95 v26.6 blend + Luxmark
DDR = MemTest64
I suggest getting a cheap replacement with unlocked multiplier off eBay and meanwhile increase vcore to unsafe levels.
866 (0.22/day)
Processor ryzen 5 5600x
Motherboard AB350m Pro4
Cooling custom loop
Memory TEAMGROUP T-Force TXKD416G3600HC18ADC01 16gbs XMP
Video Card(s) HP GTX1650 super 4gb
Storage MZVLB256HBHQ-000H1 PM981a (256GB)/3TB HDD
Display(s) Nitro XF243Y Pbmiiprx
Case Rosewill CULLINAN
Power Supply Corsair 750w
Mouse Best Buy Insignia
Keyboard Best Buy Insignia
Software Win 10 pro
if your cooling can handle it go ahead and push it to 1.4v and see if all the errors go away. if they do then start backing the voltage off until they show back up. at this point just increase it a small bit to make it stable. your voltage is fine and the chip can handle it as long as the cooling is up to the task.
820 (0.14/day)
Bristol-U.K
Storage 1TB SSD
Mouse Logitech G203
well the temps idle at about 36c and around 50c whilst gaming.
testing i have seen it hit around 85c.
going to order another tomorrow as they are only 20£ on ebay.-as back up
