System Name | Tiny the White Yeti |
Processor | 7800X3D |
Motherboard | MSI MAG Mortar b650m wifi |
Cooling | CPU: Thermalright Peerless Assassin / Case: Phanteks T30-120 x3 |
Memory | 32GB Corsair Vengeance 30CL6000 |
Video Card(s) | ASRock RX7900XT Phantom Gaming |
Storage | Lexar NM790 4TB + Samsung 850 EVO 1TB + Samsung 980 1TB + Crucial BX100 250GB |
Display(s) | Gigabyte G34QWC (3440x1440) |
Case | Lian Li A3 mATX White |
Audio Device(s) | Harman Kardon AVR137 + 2.1 |
Power Supply | EVGA Supernova G2 750W |
Mouse | Steelseries Aerox 5 |
Keyboard | Lenovo Thinkpad Trackpoint II |
VR HMD | HD 420 - Green Edition ;) |
Software | W11 IoT Enterprise LTSC |
Benchmark Scores | Over 9000 |
Depends on your preferences mostly...
'Best' is leave at default and tweak through ingame settings. Most games automatically push a pre-generated setting for each GPU that should provide playable FPS.
If you care about responsiveness, Vsync OFF in NVCP, it will reduce input lag but introduces screen tear. Beyond that its about tiny details that won't really matter or impact the 960M in a meaningful way. If you want magic bullets to improve FPS: lower resolution / lower ingame graphics settings. Its always a tradeoff.
Processor | Intel i5-12600k |
Motherboard | Asus H670 TUF |
Cooling | Arctic Freezer 34 |
Memory | 2x16GB DDR4 3600 G.Skill Ripjaws V |
Video Card(s) | EVGA GTX 1060 SC |
Storage | 500GB Samsung 970 EVO, 500GB Samsung 850 EVO, 1TB Crucial MX300 and 2TB Crucial MX500 |
Display(s) | Dell U3219Q + HP ZR24w |
Case | Raijintek Thetis |
Audio Device(s) | Audioquest Dragonfly Red :D |
Power Supply | Seasonic 620W M12 |
Mouse | Logitech G502 Proteus Core |
Keyboard | G.Skill KM780R |
Software | Arch Linux + Win10 |
If you really don't know, you should install GeForce Experience. That will set some decent defaults for you.Hi to all,
I would like to know which are the best settings for NBA 2K18 in Nvidia Control Panel?
My GPU is Nvidia GTX 960M!
Please tell me!
Thanks to all in advance!
Best regards!
Though you probably installed the driver by clicking next, next, next and you already have GeForce Experience in place.
Also, no, settings are not universal. Instead of "insisting" you should be "reading" and "catching up"![]()
Ok,thank you!![]()
I think it's best not to mess with stuff he doesn't understand. After all, the drivers come with application profiles for pretty much everything, so if a setting will benefit a title more, it's probably already configured as such.Many of the settings in NVCP are 'defined by application' on default, so they are controlled from within the game settings anyway. Those that are not are already defaulted to optimal in terms of performance. Beyond that, all tweaks are very specific and serve to either improve image quality at the cost of FPS, or to work in tandem with other specific hardware or software. A good example of that is 'Vsync' which should be combined with 'Triple Buffering' when it is on, from the control panel.
The best way to learn what settings do is by trying it for yourself, this way you get a feel for the performance cost and whether its worth it to you.
Processor | INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts |
Motherboard | ASUS PRIME Z390-P ATX |
Cooling | CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull |
Memory | CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz |
Video Card(s) | EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING |
Storage | ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND, |
Display(s) | 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved |
Case | BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE, |
Power Supply | 1600 Watt |
Software | Windows 10 |
Hi to all,
Please tell me!
Best regards!
Sure there are. Go to the control panel and move the slider all the way to "high performance" and you're done.As far as I know,there are performance tweaks for many games like setting of the program settings for those games in Nvidia Control Panel!
Wow thank you sooo much dear DRDNA!
You are my hero!
shadows med to lowWhat about the settings for NBA 2K18?
shadows med to low
AF OFF
NO CMAA OR ANY OF THAT EITHER
Thank you very much!http://steamcommunity.com/sharedfiles/filedetails/?id=766636787
Reading this, its nothing special and I think similar to what @DRDNA posted earlier. I also doubt this will noticeably improve FPS to be fair.
If your performance is abysmal, the main reason is going to be the GPU, a 960M really isn't much to write home about![]()
