- May 19, 2007
- 4,520 (0.68/day)
- Perth AU
Processor | Intel Core i9 10980XE @ 4.7Ghz 1.2v |
Motherboard | ASUS Rampage VI Extreme Omega |
Cooling | EK-Velocity D-RGB, EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM |
Memory | G.Skill Trident Z RGB F4-3000C14D 64GB |
Video Card(s) | Asus ROG Strix GeForce RTX 4090 OC WC |
Storage | M.2 990 Pro 1TB / 10TB WD RED Helium / 3x 860 2TB Evos |
Display(s) | Samsung Odyssey G7 28" |
Case | Corsair Obsidian 500D SE Modded |
Power Supply | Cooler Master V Series 1300W |
Software | Windows 11 |
I'm not sure what to do at the moment i have a EK Coolstream PE 240mm Radiator on hand will this be enough to get a good OC out of a 5930K and also cool my GPU or should i upgrade to a EK Coolstream PE 360mm Radiator or i could go dual EK Coolstream PE 240mm Radiators? I rather just get the 360mm as my 240mm is scratched up any ideas?
