I'm running a 5850 (10.3a preview drivers) on Windows 7. I just got my DP->VGA adapter but eyefinity isn't working. I have two 23" inch monitor (Acer X233H via DP->VGA adapter and H233H via DVI) on the sides of a 32" LCD TV (1360x768, via DVI->VGA adapter).
so 23" (DVI) - 32" (DVI->VGA) - 23" (DP->VGA)
I got all 3 screens to run 1360x768. However when I go to create a display group, and select the 3x1 option and press ok the displays begin to blink, then it ends up being all 3 monitors in clone mode with a res of 640x480. Now under "Desktops and Display", if I right click on the one display that's there and select property, it says the Desktop Type is "Eyefinity Duplicate", however I can only select 640x480, 800x600 and 1024x768 as resolution...
All 3 monitors are capable of running 1360x768, why won't Eyefinity work? Any pointer is much appreciated.
