Why does my Wireless NIC have a USB header?
75 (0.02/day)
Processor i7 3770k @4.3GHZ
Motherboard Asus P8Z77-V
Cooling Hyper 212 Evo
Memory g.skill Sniper 1600 4GB x4
Video Card(s) Powercolor RX480 4GB
Storage Crucial MX100 x2
Display(s) LG 25UM56-P 25"
Case Antec 1100
Power Supply Corsair HX750
Mouse Roccat Kone EMP
Keyboard CM Storm Trigger
Benchmark Scores https://www.3dmark.com/3dm/27435174
I bought that^
Didn't notice it before I bought it, but it connects internally to a motherboard USB header for some reason....
Anyone know why?
It has no manual just a guide that says plug all the things in.
It's for the Bluetooth functionality. My wireless NIC also has that header.
Ah, since I won't be using that I can leave it unplugged I suppose.
So, little more digging and discovered that 8 pin ext header is for, basically non existent products. So, that's out of the question, but it does bring rise to another question...
"Scotty, we need moar POWAH"....
In order to provide both wireless & bluetooth functions, the card needs some extra juice, thats all...
But as you said, if not using the BT, you should be able to leave it disconnected///
subbed.
Can you let me know how it works and the distance + obstacles please? I'm also on the market for some wireless. Interested how well this one works. Thanks!
Sure, it's a gift though so it might not go in for a while.
subbed.
I'll just throw my experience in here.
I have an Intel Wireless-AC 7265 NIC installed in this E-key M.2 to PCIe 1x adapter.
They're great little adapter cards (I've bought two so far and haven't had any issues with either of them). They're good for repurposing wireless NICs from old laptops.
The AP in my house is about 30 feet away from my computer, with three walls between them. Reception bounces between two and three bars in Windows.
I don't think the USB header is there to provide extra power, as the PCI-E 1x bus is already capable of powering up to 75W devices, which is well within the requirement of a wireless combo card.
I'm more inclined to this :
Exactly. "juice" comes from the PCIe slot directly, and provides it more than enough. As mPCIe/M.2 cards use 3.3V, it's better to use this exact voltage from slot, instead of adapting 5V from USB.
It's the USB connection that is needed in order to communicate with the BT portion of card.
