Why does saving an image without changing anything in Paint reduce size drastically?
9,019 (1.38/day)
System Name Black Panther
Processor i9 9900k
Motherboard Gigabyte Z390 AORUS PRO Wifi 1.0
Cooling NZXT Kraken X72 360mm
Memory 2 x 8GB Corsair Vengeance RGB Pro DDR4 3600Mhz
Video Card(s) Palit RTX2080 Ti Dual 11GB DDR6
Storage Samsung EVO 970 500GB SSD M.2 & 2TB Seagate Barracuda 7200rpm
Display(s) 32'' Gigabyte G32QC 2560x1440 165Hz
Case NZXT H710i Black
Audio Device(s) Razer Electra V2 & Z5500 Speakers
Power Supply Seasonic Focus GX-850 Gold 80+
Mouse Some Corsair lost the box forgot the model
Keyboard Motospeed
Take this picture here:
I opened it with Paint, then selected "Save As"
and voila from 3.2MB this file went down to less than 600KB while keeping it same format (jpg) and not editing anything :confused:
What's the deal here?
4,015 (0.74/day)
UK
System Name PC
Processor AMD Ryzen 3600
Motherboard MSI B450 Mortar Max
Cooling Phanteks PH-TC12DX, 3 x NZXT FN 140mm, 1x NZXT FV V2 120mm
Memory 32gb DDR4 3200mhz
Video Card(s) ASUS R9 290 DCII-OC 4GB
Storage corsair mp600 1TB
Display(s) LG 27MB85Z 27" 1440p
Case NZXT Source 340
Power Supply Thermaltake 675w
Mouse Logitech G500S
Keyboard Logitech G510S
Software Windows 8.1 64 bit
Paint saves in a higher compression ratio
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
4,015 (0.74/day)
UK
System Name PC
It really depends on the size of the picture on the moniter/how much your zoomed in as well as the complexity of what your photographing
2,406 (0.43/day)
London, UK
System Name Slick
Processor Intel i5 2467M
Motherboard Samsung Series 5 Ultrabook
Memory 8GB Corsair Value
Storage Crucial M4 7mm 256GB
Display(s) 13"
Software Windows 8 Pro x64
Try Paint.net, lets you adjust the file size /quality. Pretty much replaces stock paint imho
95Viper
Super Moderator
13,308 (2.20/day)
+1 :toast: on that, and it is free with no nags or anything.
I, myself, have donated to them, as, I use it regularly.
They, even, have an on-line community, tutorials and you can use plug-ins.
It makes use of layers, optimized for multicore and multiprocessor, special effects, auto updates(if you want it to), and a boat load more.
Paint.NET v3.5.8
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
If memory serves JPEG has 10 quality levels from 1 to 10, 10 being the highest quality. The image may have been originally created with a setting of 10 and Paint probably does ~5. This is why saving the exact same image with Paint, the size is drastically reduced.
If you don't want Paint to reduce the quality, save as bitmap or portable network graphic.
7,023 (1.31/day)
Well ... it's a rule of thumb: if image/video/audio file size decreases you lose data quality. If you take a photo saved directly from a RAW photo and save it as JPG you will lose in quality. If you will save that JPG over and over it will get worse. Each and every save will just add random noise evenly spread throughout the original image.
Btw this is a good site: http://errorlevelanalysis.com/
You can check image error level there.
7,180 (1.11/day)
+1 for Paint.net its basically what i use. Gimp for Linux, Paint.net for Windows.
13,850 (1.84/day)
System Name Dark Monolith
Processor AMD Ryzen 7 5800X3D
Motherboard ASUS Strix X570-E
Case Silverstone Kublai KL-07
I'm using Paint.NET for ages. A brilliant little thingie. Photoshop Lite if you want it that way.
It's free but still powerful enough that i never ever think of Photoshop for my needs.
Funtoss
588 (0.11/day)
New Zealand
System Name My Heater
Processor Intel Core 2 Quad Q6600 @ 3.2ghz
Motherboard Asus P5B-E Plus
Cooling Zalman CNPS 9700 NT
Memory Patriot 4GB 800MHz DDR2
Video Card(s) EVGA GTX 460 1GB
Storage 2x Western Digital 640GB (1.28TB)
Display(s) Viewsonic VX2349wm 24"
Case Raidmax Hurricane
Audio Device(s) C-Media 8738
Power Supply Aywun Megapower 650w 80+
Software Windows 7 64 Bit
Lol, i always wondered as well :L
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Not necessarily. Saving a bitmap as a PNG will substantially reduce the side of the file but the quality is exactly the same.
BMP is lossless and uncompressed.
PNG is lossless and compressed
JPG is lossy.
1,132 (0.18/day)
System Name Grandpa
Processor i5 4690K
Motherboard Gigabyte Z97X-UD5H-BK
Cooling water
Memory 8GB Corsair Vengence 2400MHz
Video Card(s) Gigabyte 5850 x2
Storage Samsung SM951
Display(s) Catleap 27"
Case coolermaster stacker
Power Supply corsair AX860i
Mouse logitech g5 original
Keyboard Ducky
.jpg is a compression format (i.e. lossy) so it will always be smaller. If you want to save the quality of a picture, you should select .bmp.
i.e. if you are doing lots of editing/saving/editing/savings etc - use .bmp and then when you are finished, save as .jpg - don't use .jpg as an editing format
7,023 (1.31/day)
JPG is lossy.
Png is not lossless. My trained eyes can spot the difference.
13,850 (1.84/day)
PNG is lossless unless you're using some crappy encoder that does it in a lossy way.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
I doubt a crappy encoder exists. PNG is all standardized. The images (any image -> PNG) are 1:1 identical except in binary. PNG is lossless and always has been.
12,171 (1.71/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Yup, which is why PNG is excellent for images with large areas of solid color.
3,051 (0.60/day)
System Name The SwagMachine / The Sister
Processor Core i5 3570K @5.2ghz 1.3V/ 1100T
Motherboard ASUS P8Z77-V / ASUS M5A99X EVO
Cooling Phanteks PH TC14PE / Corsair H40
Memory M379B5273DH0-YK0 2X4GB + PVI316G213C1QK 2X4GB / 2x4GB Patriot 2133
Video Card(s) PNY 780Ti /Windforce 7950
Storage 2xSamsung 840 EVO 250gb+WD10EZEX + WD30EZRX/ 1x WD1500 Black
Display(s) AOC Q2963PM+Acer S200HL / Acer S200L+ LG 22LD350
Case Fractal Define R4 / NZXT Trinity
Audio Device(s) Asus Xonar DG / Asus Xonar DG
Power Supply Seasonic 750X / ROSEWILL RG630-S12 630W R
Mouse Razer Deathadder Chroma / Roccat Kone+
Keyboard Razer Blackwidow 2013 Stealth / Roccat Isku
Software Windows 8.1 Pro / Windows 7 Ultimate
Benchmark Scores one time I scored a 3 on 3dmark 11
It's because a raw image has ROM files which have coulor settings and such, when you put it in paint it deletes it and them compresses some part of the image
4,686 (0.75/day)
System Name Obelisc
Processor i7 3770k @ 4.8 GHz
Motherboard Asus P8Z77-V
Cooling H110
Video Card(s) GTX 780 Ti
Case T81
Software Win10 64bit
I know for photoshop at least jpg has 12 levels. I usually go with 10. I switched to either saving everything in png or pasting screenshots into photoshop instead of paint as the compression in paint just ruins game screenshots. Like why even bother saving with how crappy it looks... unfortunately it took me awhile to pay enough attention to notice the dithering and what not so I have all these shitty quality old screenshots. Now though I just use fraps with png.
7,023 (1.31/day)
The official png website states that png is inherently lossless
filters can be added to it to make it lossy and hence provide greater compression
http://www.libpng.org/pub/png/pngintro.html
And btw if you have no idea JPEG 2000 and JPEG 1992 are truly lossless
http://www.jpeg.org/jpeg2000/
Squeezemaster
1 (0.00/day)
Someone recently suggested that I use MS Paint in my Win 7 machine to reduce file size without reducing image size. I gave it a try. I opened a 137mb tif file that was exported from LR 5 with the Prophoto RGB color profile into MS Paint and immediately saved it as a tif without changing anything to the file. The resulting tif file was only 14.8 mb! The image size was identical to the 137 mb file. Paint did not change the color profile. I opened both files in PS CS6 side by side, extremely zoomed in on areas of the image and could not tell the difference by looking at them on the monitor. There was no banding as usually seen in compressed jpgs. No apparent loss of detail at all. I have been looking online for an explanation for HOW Paint does this and found this relatively old thread. No real answers to be found here but at least the topic is addressed. I can understand compressing a jpg to reduce file size, but not a tif file. My plan is to make extreme crops from both files and have them printed to see what I get. This should be the real test for the MS Paint file size reduction. BTW, I have over 35 years of professional photography experience and look at images very critically.
