Why does "Scanning Process" appear is task manager and what is it?
KBD
2,477 (0.37/day)
The Rotten Big Apple
Processor Intel e8600 @ 4.9 Ghz
Motherboard DFI Lanparty DK X48-T2RSB Plus
Cooling Water
Memory 2GB (2 x 1GB) of Buffalo Firestix DDR2-1066
Video Card(s) MSI Radeon HD 4870 1GB OC (820/950) & tweaking
Storage 2x 74GB Velociraptors in RAID 0; 320 GB Barracuda 7200.10
Display(s) 22" Mitsubishi Diamond Pro 2070SB
Case Silverstone TJ09-BW
Audio Device(s) Creative X-Fi Titanium Fatal1ty Profesional
Power Supply Ultra X3 800W
Software Windows XP Pro w/ SP3
I'd like to know what this item called scanning process is doing in windows task manager and what does it do? I have 2 instances of it running and each take a considerable amount of resourses (24,000K each), is this something i need or i can turn it off?
Kreij
Senior Monkey Moderator
13,817 (2.08/day)
Cheeseland (Wisconsin, USA)
I believe it is a process used by ZoneAlarm.
GJSNeptune
2,570 (0.39/day)
Ohio
Processor AMD Athlon 64 X2 5000+ Black Edition
Motherboard Gigabyte GA-MA770-DS3
Cooling Tuniq Tower 120 (with Scythe SFF21E)
Memory 2x1GB Corsair XMS2 DDR2-800 CAS4 DHX
Video Card(s) PALiT 9800GTX 512MB PCI-E
Storage WD2500AAKS, WD1600YS, WD1200JD, WD400EB
Display(s) LG L1920P, Viewsonic VA520
Case Lian-Li A05b (with two 120mm Yate Loon D12SM)
Power Supply Corsair HX520
Software Vista Business 32-bit/XP Pro 32-bit dual-boot
Is that what the process is actually called? If it's not from your AV, run HijackThis!
And then analyze it here.
WarEagleAU
Bird of Prey
10,812 (1.57/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
yeah, usually is the background use of your antivirus, antiscript, antispy and anti adware programs running in the background. You can usually turn these off. They are basically there to scan for viruses, intrustions, etc. and in no way harms your computer. Some of them do take a bit of resources, 24k being some of the biggest, but it shouldnt hurt your pc's performance.
KBD
2,477 (0.37/day)
Cooling Water
Yea, i am running ZoneAlarm Security Suite so i guess that could be it. I just tried turning off the antivirus and antispyware in the firewall but i'm still seeing those tasks. I also have Spyware Terminator and Windows Defender in Startup but i don't think that's them. Also, the Scanning Process thing is labeled SYSTEM, the stuff i added is labeled ADMINISTRATOR, so may be its not ZA?
WarEagleAU
Bird of Prey
10,812 (1.57/day)
Gurley, AL
try hijack this, but I doubt it is. There still is something running in the background to check. Even if you turn off ZA it still has a resident in memory scanning for any infections.
KBD
2,477 (0.37/day)
Cooling Water
Guys, i just rebooted the PC and guess what, the Scanning Process is gone, looks like it was ZA AV and AS stuff. I guess i should reinstall AVG, that stuff doesnt eat up resorses like crazy.
