- May 11, 2025
- 180 (2.34/day)
System Name | ReactorOne |
Processor | AMD 9800X3D |
Motherboard | MSI MAG X870E TOMAHAWK WIFI |
Cooling | ARCTIC Liquid Freezer III Pro 360 |
Memory | G.SKILL Flare X5 32GB DDR5-6000 CL28 |
Video Card(s) | PNY RTX 4080 Super 16GB Verto OC |
Storage | 2TB Samsung 990 Pro / 2TB WD SN850 / 8TB WD Red Plus |
Display(s) | LG 32" 1440p 16:9 165hz |
Case | Fractal S |
Audio Device(s) | Aune X1S Anniversary / Edifier R1700BT |
Power Supply | Dark Power 13 1000W |
Mouse | Evoluent VerticalMouse 4 |
Keyboard | Corsair K65 Plus Wireless 75% Mechanical, Hotswappable Switches |
Software | Windows 11 Pro |
Benchmark Scores | It's over 9000! |
The two main sources of heat are the CPU and GPU. Why are they located in the same compartment? Wouldn't it make more sense to separate them so that case fan curves for the different zones could reflect whatever component was actually in there? I heard that a riser cable for a GPU doesn't impact performance significantly so this should be entirely possible.
I say this as a user who is considering an AIO because I want better airflow for my mobo and GPU, not because I think the CPU needs it.
