Why is Condemed not full screen?
2,050 (0.29/day)
Venice
System Name Amber
Processor AMD Athlon 64 x2 3800+ Toledo 3.0GHz/2.0GHz 1.5V
Motherboard DFI Lanparty UT NF4 SLI Expert
Cooling Air: 1 80mm-Intake-top | 4-120mm 3-intake-1-exhaust | Proc 120mm blue orbII | N.B-T.T Key 3|
Memory 2GIG, 4x512 Kingston Hyper-X DDR333 PC 2700@167Mhz |2-2-2-5|-7-1T-8(CPU-Z) Dual channel
Video Card(s) 2 PNY Verto 8600GT'S in SLI, 670MHz/540MHz(Core)800MHz/700MHz
Storage 320 Gig Western digital SATA
Display(s) Sony 17" LCD 1280x1024 @ 75Htz
Case Sunbeam clear acrylic
Audio Device(s) Native Instuments Guitar Rig 3
Power Supply 520 Watt Aspire Dual rail +12#1 16 amps +12#2 18 amps(I think)
Software Fedora Core 8, Windows Vista
I bought Condemned: Criminal origins, I maxed out the settings:D and it doesn't go full screen its like when you watch a wide screen dvd, I can set it to weird resolutions and somewhat make it go all the way but then it looks like crap and still has bars at the top and bottom. I go the res at 1280x1024, anybody have this problem?
just keep changing the resolution till it fills the screen like you said .
i think if you look closely when youre changing resolution, it says something like
"not optimised for full-screen" when the resolution leaves bars
Do you mean it has black on the top and bottom of the screen like when u watch a widescreen dvd on a 4:3 tv? thats the way the game is i think... does it with my monitor also.
I had the same as you. Mine was black at the top and bottom. It looks flat.
Wow thats the worst programming I have ever heard of. Thanks for the replies anyways.:shadedshu
