why is my 3dmark '06 score soooo low!?!?!
Q
quasar923
Ok i just built this new comp listed in my specs. i built it last friday, had an OS installed this past sunday. I am using XP 64 bit. anyways my 3dmark '06 score was only 11,714 marks, my cpu score was 3,618 OCed at 3.87ghz. then today i ran 3dmark at cpu stock speeds of 3ghz and i got 1,000 points lower on the cpu score and total score all together which makes sense, just trying to give more info. i have CCC 8.8 beta installed. My friend whose comp i helped build (fafa2121 here on tpu) gets 12,300 and hes only has a e6750 which was OCed to about 3.6ghz, powercolor HD3870, Asus x38 mobo, 2 gigs of crucial balistix pc 8000 (1000mhz), and a 700 watt psu. What is holding me back? are the drivers for the 4850 not efficient yet?
5,052 (0.75/day)
Manchester, United Kingdom
Processor AMD 5800X3D
Motherboard Asus Strix B550-F Gaming
Cooling Corsair H100i
Memory 2 x 32GB Corsair Vengeance
Video Card(s) Sapphire Pulse 6800XT
Storage 1 x 1TB 980 PRO, 1 x 1TB Corsair MP510 Force
Display(s) 1 x Dell 27" 165hz
Case Lian-Li O11D Evo
Power Supply EVGA 1000W P2
Keyboard Logitech G915
Software Windows 11 Pro x64
What drivers are you using?
My E8400 @ 3.6Ghz, HD4870 at stock with 4Gbs of 1000Mhz DDR2 got 14k.
Q
quasar923
Driver Packaging Version 8.52.2-080722a-066078E-ATI
Provider ATI Technologies Inc.
2D Driver Version 6.14.10.6844
2D Driver File Path System/CurrentControlSet/Control/Video/{D3A56B67-0910-4BBE-A3EB-077A2E8E395C}/0000
Direct3D Version 6.14.10.0603
OpenGL Version 6.14.10.7869
Catalyst® Control Center Version 2008.0722.2157.37438
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
8.7's are the proper drivers but the 8.8 beta's should work almost as good. What are your temps(idle and load)? What are your sm2 and sm3/hdr scores in 3dmark06?
62 (0.01/day)
Malta, Europe
Processor Core 2 Duo E6600 @ 3.0GHz
Motherboard Asus P5B
Cooling Antec Kuhler H20 620
Memory Corsair TwinX 2x2GB
Video Card(s) Asus EAH 4850 512mb DDR3
Storage 3x Maxtor 160GB 7,200RPM
Display(s) 32" LG
Case Cooler Master HAF 932
Audio Device(s) SteelSeries Siberia external Soundcard
Power Supply Corsair 850W
Software Windows 8 Pro x64
afaik 3dmark isn't very kind when it comes to the HD4800 series. I could be wrong. But still, that wouldn't explain the 1000 point drop.
Q
quasar923
my gpu idle temps are around 55C and load about 68C
cpu is 40C idle when OCed to 3.87, and i havnt taken load temps on cpu because i dont have any games installed yet. but ill guess its mid 50s C*
5,052 (0.75/day)
8.7 uses older display drivers than the 8.7 and 8.8 betas. 8.7 uses 8.152, and 8.7 and 8.8 betas use 8.52
Q
quasar923
so then why is my score soo low compaired to my friends comp which is obviously infearior to mine hardware wise.
ktr
7,404 (1.06/day)
I think the chipset is to blame...p45 vs. x38. I personally don't know what the benches between them are, but that is my guess.
Q
quasar923
Only in crossfire (p45 is two 8x, while x38 is two 16x). But I doubt there is any difference in single card.
oh well he only has one 3870 so why would he get a higher score with a worse gpu, ram, and cpu?
ktr
7,404 (1.06/day)
Its either poor drivers, or a bottleneck somewhere...perhaps gcard and chipset.
Q
quasar923
how is a 4850 holding back my cpu? and whats wrong with the p45 chipset? and also whats the diff between ich9R and 10R?
Q
quasar923
should i set the fsb-NB strap to 400mhz instead of auto?
mas0n
88 (0.01/day)
dallas
Processor Q6600 425x9=3825MHz @1.4625V
Motherboard DFI DK X38-T2RSB
Cooling PA120.3, Apogee GT, Swiftech MCP655-B
Memory 4GB Patriot 4-4-4-12 @425MHz
Video Card(s) HD4870 @ 820/1100
Storage 2x74GB | 2x400GB | JBOD 1.8TB
Display(s) Samsung 225BW
Case Antec P180B
Power Supply PC Power & Cooling 610W Silencer
This series does just fine in 3DMark06. I'm getting ~18,000 with rig in specs.
quasar923, I think you should attempt to rule out a driver problem.
Uninstall ATI drivers and CCC. Reboot.
Delete C:\Documents and Settings\%USERNAME%\Application Data\ATI
Delete C:\Documents and Settings\%USERNAME%\Local Settings\Application Data\ATI
Delete C:\Documents and Settings\All Users\Application Data\ATI
Delete C:\Program Files (x86)\ATI Technologies
Install and Run Driver Cleaner Reboot
Install 8.7 drivers, don't mess with the beta drivers until you clear this up. Reboot
Test and Report
Also, I don't have time to look. What does ORB suggest you should be getting?
6,871 (1.09/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k 5.1GHz all cores
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) RTX 4080 FE
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Corsair - HS70 PRO headphones
Power Supply Corsair RM850x (2021)
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Software Windows 11 Pro 64 bit
Benchmark Scores https://www.3dmark.com/spy/34962882
by any chance, is your friend using one of the 3870 with 1 gig of memory on it. That could explain why he scores higher
boogah
887 (0.14/day)
Houston
System Name Core i7 WS
Processor i7 920 D0 @ 4.2 GHz
Motherboard ASUS P6T WS Professional
Cooling Thermalright Ultra 120 Extreme RT1366
Memory 6gb 3x2gb Crucial DDR3
Video Card(s) Firepro V8700
Storage Velociraptor 300gb in raid0
Display(s) 2x Dell Ultrasharp 24"
Case Antec Twelve Hundred
Audio Device(s) onboard sound
Power Supply Corsair HX1000
Software Windows 7 64-bit
1 gig of ram on the card doesn't make it faster... just more buffer room for high resolution 1600 x 1200 +
6,871 (1.09/day)
S.E. Virginia
it may not nessarily make it faster, but it would improve it's benchmark score.
43,629 (6.36/day)
Test and Report
Follow this advice!^^^
Use Orthos to test your CPU temps under load.
boogah
887 (0.14/day)
Houston
no sir. especially since the 1gb version is GDDR3 vs the 512mb version running GDDR4. I have tested all of these cards. :cool:
6,871 (1.09/day)
S.E. Virginia
I stand corrected. I missed the ddr3 and ddr4 difference between the two cards.
