- Jan 17, 2022
- 31 (0.03/day)
Hi there,
yes, the question would seem to answer itself, but let me elaborate.
For the past few month, ive been seeing odd spikes in GPU clock + usage with desktop programs that have never needed so much juice in the past, including:
*Autocad
*Revit
*Adobe Premier Pro
*Adobe Indesign (but only when typing text)
Basically, the GPU suddenly seems to treat using these programs as though they were games. If i just run the mouse over an empty Revit file, the GPU clock shoots up to load levels and the usage spikes to 70-80%.
Strangest things is that in other just as 3D intense programs like 3DS Max or Sketchup, the GPU clock+usage behaves as it should, never leaving the base clock and only using about 10-15% tops.
I'm still running tests on different things to see where this problem is coming from - Nvidia drivers, Windows or BIOS are my lead suspects. I've rolled back drivers and the problems gone away (very telling), however it
reappeared out of nowhere after 2+ weeks of normal use on the most recent driver - HOWEVer, while it is certainly abnormal behaviour, the computer still runs great. GPU heat never gets out of control, game still run
fine and the affected programs mentioned above still work as expected.
The question is: is it okay to work with the machine while the GPU is bouncing up and down to such extremes like that? The clock remains steady at load levels (like it would for games) while using these programs, but the usage is up and down like
a schizophrenic rollercoaster.
*Autocad
*Revit
*Adobe Premier Pro
