Will an i7 7700 bottleneck a RTX 3060 Ti?
Fourstaff
10,089 (1.79/day)
Home
Processor 3570K // 10400F
Cooling Stock // Stock
Should be a decent combination. 1080p is not that demanding, even at 144Hz.
18,584 (2.64/day)
System Name AlderLake
Is it a high refresh monitor?
If it's a 60Hz monitor, then no bottleneck at 60fps.
If it's a high refresh 144Hz(+) monitor, probably yes, depends on the game.
9 (0.01/day)
It is 144hz. I hope it is not much because I need to buy it anyway.
18,584 (2.64/day)
You can upgrade CPU/Motherboard another time.
I will probably buy a 3080 and I have a 6700K @ 4.5Ghz but I run at 1440p 165Hz, also a bottleneck, will upgrade CPU/Motherboard/RAM later, some other time.
1,005 (0.15/day)
Processor i9 10850k
Motherboard Asus strix Z-490-e
Memory G.SKILL Trident Z 4000mhz
Video Card(s) Asus STRIX RTX 3080
Storage 1tb Samsung 970 EVO,1tb hdd,750gb hdd
Display(s) Asus 27" 144htz 1440
Case Lian Li lancool 2 mesh
Power Supply Seasonic GX-850
Keyboard Logitech Pro
Yes it will bottleneck it.
my brother has my 3080 right now and he said it’s 4fps faster than his 2080 super at 1080p he has a 7700k @5ghz
It will work good for you but you will see improvement with a better cpu.
23,826 (6.15/day)
It will be highly game dependant.
If game/engine can use HT, then you have 8 threads and it won;t be major. If the game is stuck with the 4 physical cores, the bottleneck is potentially major and variable as background processes can eat away at your game performance too.
But its a bottleneck either way. If you have a choice, invest in 6+ physical cores. 4 is old news.
9 (0.01/day)
Could the bottleneck cause 20 fps decrease in performance? I hope it is not that much.
448 (0.24/day)
Panama City Beach, Florida
System Name EventHorizon
Processor Intel® Core™ Processor i9-13900KF 8P/16 + 16E 3.00GHz [Turbo 5.7GHz] 36MB Cache LGA1700
Motherboard ASUS PRIME Z790-P
Cooling CyberpowerPC MasterLiquid Lite 240mm ARGB CPU Liquid Cooler
Memory 32GB (16GBx2) DDR5/6000MHz Dual Channel Memory (KINGSTON FURY BEAST RGB)
Video Card(s) GeForce RTX™ 4080 16GB
Storage 2TB WD BLACK SN850X (PCIe Gen4) NVMe M.2 SSD - Seq R/W: Up to 7300/6600 MB/s, Rnd R/W up to 1200/110
Display(s) LG 34''
Case CyberPowerPC HYTE Y60 Dual Chamber Mid-Tower Gaming Case w/ Panoramic View Tempered Glass + 2x120mm
Audio Device(s) SteelSeries Sonar
Power Supply High Power 1300W 80+ GOLD Full Modular w/ PCIE 12+4Pins Connector for PCIe 5.0 graphics cards
Mouse Steelseries Rival 600 wired
Keyboard Steelseries Apex 7 TKL red Switch
Software Win 11 Pro
Will an i7 7700 (non-K) bottleneck a RTX 3060 Ti? My monitor is 1080p
Ruru
S.T.A.R.S.
13,763 (3.05/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + EK Vector TUF + Acool XT45 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC
Video Card(s) Asus RTX 3080 TUF / Powercolor RX 6700 XT
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector @ 90"
Audio Device(s) Sony WH-CH720N / Hecate G1500
Power Supply EVGA G2 750W / Seasonic FX-750
VR HMD Oculus Rift CV1
Think it as an i3-10100F as it's basically the same and check if there are some reviews with that.
It is a bottleneck for sure.
4,928 (0.97/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
depends on the exact game but the combination will provide more than playable FPS
  • Like
Reactions: Rei
19,379 (3.46/day)
You'll see an improvement, sure, however, as others have said, it depends on the game as to how much. The problem is more so the 4c/8t honestly.
636 (0.14/day)
Technical Tittery....
System Name "IBT 10x Maximum Stable"
Processor Intel i5 4690K @ 4.6GHz -> 100xx46 - 1.296v
Motherboard MSI MPower Z97
Cooling Corsair H100i + 2x Corsair "HP Edition" SP120's
Memory 4x4GB Corsair Vengence Pro 2400mhz @ 2400MHz 10-11-12-31-1T - 1.66v
Video Card(s) MSI Gaming GTX970 4GB @ 1314 Core/1973 Mem/1515 Boost
Storage Kingston 3K 120GB SSD + Western Digital 'Green' 2TB + Samsung Spinpoint F3 1TB
Display(s) Iiyama Prolite X2377HDS 23" IPS
Case Corsair Carbide 300R
Audio Device(s) Rotel RA-04/Cambridge Audio Azur 540R + B&W DM302/Cerwin Vega AT12 / Sony MDR-XB700 & FiiO E5
Power Supply EVGA NEX650G + Silverstone Extensions
Mouse Always failing me....
Keyboard Endlessly broken.....
Software Windoze 7 Pro 64-bit/Windoze 10 Pro
Benchmark Scores I had some of these once upon a time? Old age has seen me misplace them....
Can I get a moment of sympathy for my lowly 4c/4t CPU still kicking it in 2020; soon to be 2021?!
"1 like = 1 sympathy"
(just buy the card if you can, before it goes out of stock!)
4,928 (0.97/day)
It's really where you plant your goalpost, the 7700 non-k is very similar to the current i3-10100 (as mentioned above) You still are looking at very good FPS across the board and even in a difficult game like RDR2 the FPS avg is over 75.
1,839 (0.49/day)
System Name Legion
Processor i7-12700KF
Case Montech Air X
Power Supply Corsair CX750M
Mouse Logitech MX Anywhere 25
Keyboard Logitech MX Keys
Software Lots
The bottleneck always dedpends on the game, but short answer is yes.
This post on SOTR benchmarks is enlightening.
A 7700K w/2080 Super getting 124FPS at 1080P on that test. He is 11% GPU bound hence 89% CPU bound. The 2080 Super GPU can render at 165 FPS avg so he is losing around 40FPS due to CPU limitation.
A 3060 Ti is slightly faster than a 2080 Super, so you will definitely lose a lot in many games.
51 (0.01/day)
Canada
System Name AORUS Elite Ice™
Processor Ryzen 7 9800X3D
Motherboard Gigabyte X870 AORUS ELITE WIFI7 ICE
Cooling Arctic Liquid Freezer III 240 A-RGB White
Memory CORSAIR Vengeance RGB 32GB (2x16GB) DDR5 6000MHz
Video Card(s) GIGABYTE AERO GeForce RTX 4090 24GB
Storage Samsung 990 Pro 2TB/Samsung 980 Pro M.2 1TB /1 x Samsung 970 Evo Plus 1TB/Samsung 850 Pro Series 1TB
Display(s) Samsung S95B / LG 27GR95QE-B 27" 240Hz 1440P / ASUS TUF Gaming VG27AQ 27" 1440P 165hz
Case Lian Li Lancool II Mesh RGB White
Audio Device(s) Creative Sound BlasterX AE-5 Plus Pure Edition W/ Logitech Z-5500 5.1
Power Supply Seasonic FOCUS Plus 850W Gold
Mouse Logitech G502 Hero K/DA
Keyboard Corsair K70 RGB MK.2 SE RAPIDFIRE Cherry MX Speed
Software Windows 11 Pro x64
I do get a slight bottleneck with my 3080 with my 7700K it depends on the games though but in 1440p with 165hz monitor so it does help in a way.
23,826 (6.15/day)
No. Retire it, it has earned it by now
The problem is also that a CPU bottleneck isnt pretty on system responsiveness, frametimes... etc
A faster gpu can turn games into a stutterfest if the gpu isnt hard capped. The gap between top and bottom FPS gets larger
  • Like
Reactions: Rei
636 (0.14/day)
It really has; but its my personal little project. :p
(Taken from SSD SMART data - SSD was new for this build)
And thanks for the rig sympathy, folks! Maybe now its (the rig, of course!) been inspired by the social exposure/likes, it'll make it to that 50k barrier. :p :lovetpu:
