will that work?
bigbadwolf284
94 (0.01/day)
new york
Processor amd 3200+@2.2
Motherboard biostar
Cooling all air....lol
Memory never enough.....
Video Card(s) 7600gt @600/820
Storage 160 GB sata
Display(s) 19 widedscreen acer lcd
Case thermaltake soprano
Audio Device(s) SB
Power Supply 500W ultra
Software XP PRO
Memory Expansion
The NF4SLi-A9 provides 4 DIMM sockets using Dual Channel 184-pin DDR with a total capacity of up to 4GB. You can install DDR 333/400MHz Memory.
Thats what it says right on the link you gave..Id look for another board i'm sure you can find one that supports DDR500 for less!!
does amd board supports ddr500?
you people are dumb.
you overclock your memory to get it to run that fast. as long as the motherboard can do 250fsb, and your processor could handle running at 2.5 Ghz, then yes, it will be fine.
id go for the Patriot XBLK 1gb kit. http://www.newegg.com/Product/Product.asp?Item=N82E16820220033
only because thats what i have, and itll take anything. i took my RAM up to 235 MHz earlier today at 1.5-3-2-5 timings. confusing, but it worked. itll do up to 225 at 1.5-2-2-5 timings. DDR600 is easy. 2.5-4-4-8 timings, 2.7vdimm. no problem.
great stuff.
