- May 19, 2007
- 4,520 (0.68/day)
- Perth AU
Processor | Intel Core i9 10980XE @ 4.7Ghz 1.2v |
Motherboard | ASUS Rampage VI Extreme Omega |
Cooling | EK-Velocity D-RGB, EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM |
Memory | G.Skill Trident Z RGB F4-3000C14D 64GB |
Video Card(s) | Asus ROG Strix GeForce RTX 4090 OC WC |
Storage | M.2 990 Pro 1TB / 10TB WD RED Helium / 3x 860 2TB Evos |
Display(s) | Samsung Odyssey G7 28" |
Case | Corsair Obsidian 500D SE Modded |
Power Supply | Cooler Master V Series 1300W |
Software | Windows 11 |
hi windows memory test says i have hardware problems and Orthos fails saying
Type: Blend - stress CPU and RAM Min: 8 Max: 4096 InPlace: No Mem: 3837 Time: 15
CPU: 3000MHz FSB: 333MHz [333MHz x 9.0 est.]
11/08/2007 8:06 PM
Launching 2 threads...
2:Using CPU #1
1:Using CPU #0
2:Beginning a continuous self-test to check your computer.
2
ress Stop to end this test.
1:Beginning a continuous self-test to check your computer.
1
2:Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
1:Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
2:Test 2, 4000 Lucas-Lehmer iterations of M19922943 using 1024K FFT length.
1:Test 2, 4000 Lucas-Lehmer iterations of M19922943 using 1024K FFT length.
2:Test 3, 4000 Lucas-Lehmer iterations of M19374367 using 1024K FFT length.
1:Test 3, 4000 Lucas-Lehmer iterations of M19374367 using 1024K FFT length.
2:FATAL ERROR: Rounding was 0.5, expected less than 0.4
2:Hardware failure detected, consult stress.txt file.
2:Torture Test ran 5 minutes 4 seconds - 1 errors, 0 warnings.
2:Execution halted.
1:Torture Test ran 5 minutes 4 seconds - 0 errors, 0 warnings.
1:Execution halted.
What could be causing this problem? windows runs fine most of the time some times in games my computer freeze
please help could it be my motherboard? its not the video card i've had to both did the same and don't no if its the ram cpu is a mouth old
11/08/2007 8:06 PM
2:Using CPU #1
1:Using CPU #0
2
1
2:Execution halted.
1:Execution halted.
