Wireless causing speaker noise
ov2rey
140 (0.02/day)
System Name Melissa pc
Processor Intel Core i7-2600K
Motherboard GA-P67A-UD4 B3 F5 Beta Bios
Cooling Corsair H60 water cooling
Memory G.Skill RIPJAWS-X CL7 DDR3-1600 16GB [Dual Channel]
Video Card(s) Palit GTX580 3Gb DDR5 x2 SLI
Storage WD Caviar Black 1TBX2 Sata3 Raid 0 /WD 640G Black SATA-II
Display(s) Dell UltraSharp U2311H 23" IPS
Case Lancool PC-K63 "First Knight Series"
Audio Device(s) High Definition Realtek ALC892
Power Supply Corsair AX1200 modular
Software Microsoft Windows 7 Build 7601 64bits SP1
hi guys.. mi have a wi-fi "wireless network" router once it connected to a computer or devices my speaker will have a buzz buzz noise.
i worry that my speaker will spoil cause by this wi-fi.
is there anyway to protect it?
other then moving away the router
The noise from WiFi will not damage your speaker/amplifier, but can be very annoying.
There's no easy way of fixing it.
The best is to move everything away from WiFi antennas.
Particularly sensitive is the audio cable connecting your PC with the speaker system (non-amplified signal). Try re-routing this cable, so it's away from WiFi.
You may have luck trying to use higher quality cable, but I doubt it will help much.
Cheers
Not true
To OP:
First thing replace your audio "signal" cables (like the RCA or 3.5 mm cables) and get something that is properly shielded. Very cheap cables tend to use less or no shielding which causes the problem you mentioned. Don't get Monster cables either! they are rip off in my opinion. Home depot or radio shack are good places to shop for quality cables in decent pricing. And secondly, route the cables so that they are away from any AC power source. Wireless signal does NOT cause electro-magnetic interference but AC power source can certainly cause that due to the high amount of magnetic flux generated (due to high voltage and amps that runs through those wires).
no need for qualification, that's objective fact. Monster Cables rips off consumers.
everything else was good ;)
