- Feb 22, 2016
- 2,307 (0.69/day)
Processor | Intel i5 8400 |
Motherboard | Asus Prime H370M-Plus/CSM |
Cooling | Scythe Big Shuriken & Noctua NF-A15 HS-PWM chromax.black.swap |
Memory | 8GB Crucial Ballistix Sport LT DDR4-2400 |
Video Card(s) | ROG-STRIX-GTX1060-O6G-GAMING |
Storage | 1TB 980 Pro |
Display(s) | Samsung UN55KU6300F |
Case | Cooler Master MasterCase Pro 3 |
Power Supply | Super Flower Leadex III 750w |
Software | W11 Pro |
Came across this small program on github while idly poking around the controller world. It allows you to perform a highly variable test using 1000, 2000, and 4000 samples to determine a few metrics related to latency by measuring your Left stick movement throughout the selected period. It took me a few tries to start getting reliable results within an acceptable margin of error.
Maybe some of you find this fun and I have no idea if the program can be used in a way that gives extremely high or low results. Which can be fun in its own right.
For the broadest results please select the 4000 Samples test.
8BitDo Ultimate 2C Wired (claimed 1000 Hz polling rate under lab conditions)
XBOX360 Wired (known disconnecting issues - tested for fun)
Logitech F310 Wired
Logitech F310 Wired
