I've spent like a whole night reading up on flashing the XT to an XTX.
And yes i know it's better to OC than to flash.
I've also come across this guy on this forum saying he has an XT with the 1.2ns vram, and he flashed his to an XTX.
The guy here did it
Now i'm asking, is it possible?
Because i was one of the unlucky ones and got an XT with the 1.2ns Infinetion mem chips. (horrible, i know)
There are 2 Toxic XTX bioses here
One says Samsung 1.1ns, and the other, would it be a 1.2ns bios maybe?
Well, he also did say he modified the toxic XTX bios to be compatiable with the 1.2ns vram.
Could anyone help me on modifying the toxic XTX bios?
AND the most important thing would be, that guy flashed his XT with 1.2ns vram, so can i right?
Edit: I just googled up x1900xt 1.2ns speeds, and apperernlty 800mhz IS the speed for 1.2ns memory chips
http://www.google.ca/search?hl=en&q=x1900xt+1.2ns+speed&btnG=Google+Search&meta=
To be more precise,
http://www.digit-life.com/articles2/video/cf2.html
Look at the memory chip if you scroll down, you'll see they said 1.2ns corresponds to 800mhz
Hmmm....
I even have my card clocked at 688/873 core and mem respectively.
So if modding the xtx bios to 800mhz, the card should turn on and work properly right?
But the question is, the toxic's bios is at 806mhz, and i should modify the ram to be 800mhz.
Does the 6mhz really makes a difference if yoru card works properly after the flash or not?
The guy here did it
To be more precise,
Hmmm....
