Addicus1337
- Mar 15, 2006
- 11 (0.00/day)
As soon as I open up ATI tool, the latest beta version available, things start to go wrong. Sometimes ill just be using it for fan control, and it will lock up while im just screwing around on the desktop. Other times when im trying to overclock, as soon as I hit “find max core” or “find max mem”, the screen does a weird artifact flash for a second, works normally for a few seconds, then weird flashes across the screen start to show up horizontally in quick flashes spaced out by about 5 seconds. If I allow this to go on for a few mins the computer will also crash.
Anyone know why this card is doing this to me? Does it need to be configured for over clocking somehow? It seams to be resisting any type of action ATI tool is throwing at it. How can I subdue this beast and bend it to my will?
Card works fine with ATI tool closed and no OC applied. Just incase though I did do a clean driver wipe then install of the latest 6.3 cats. Also did a virus scan and every other thing I could think might be causing this. Anyone got an idea? Thanks
PS. ive tryed other versions of ATI tool also, same problem, also, tempatures are not a problem, card stays nice and cool.
