tl;dr version: Is quad-channel pointless in the current market?
Hey so I'm designing a system to replace an i5-2500k (yes it has solidly lasted till now!), and am finding out that
AMD has really changed the playing field since I was last paying attention (awesome).
My intention was to head to an enthusiast chipset on my next upgrade, specifically for the benefits of quad-channel memory.
BUT
None of the benchmarks I'm seeing in the x299 and x399 space are beating LGA 1151 or X470. That's not wholly surprising when
it comes to single core applications. What's throwing me off is that there isn't a giant difference in benchmarks on multi-process,
and more modern games.
Are reviewers just not properly utilizing the enthusiast systems? The general wisdom, in favor of quad-channel memory, back in the day
was that all things being equal: 4 x 1GB will always outperform 2 x 2GB. More memory loaded onto a single channel would increase access time,
require higher voltage (to achieve equal performance), and potentially create a bottleneck.
All of the reviews I see, instead are focused on the RAM cap (64GB vs 128GB) and extra PCI-E lanes as being the benefit of enthusiast builds, which is not helpful when
they're neither increasing the RAM in system comparison, nor switching to a multi GPU (2 or 3 16x PCi-E SLI or Crossfire, where non-
enthusiast is stuck with 1x16 and 1x8 for multi GPU).
But back to the RAM...
Is there just too much RAM loaded onto channels now to even see this benefit of smaller loads? (Who in the world would put 128GB into a gaming rig?
32GB is P L E N T Y. Games haven't come far enough to make 16GB standard, even. Though I think for 3 - 5 year future proofing, they definitely will).
To make matters a little more confusing, is I'm reading that the Ryzen chip design relies heavily on RAM clock speeds to pull off
advertised numbers. The reviews are throwing the same slower RAM they use on dual channel systems, onto quad channel systems when comparing the two.
(Which makes some sense for a comparison, but totally hides the designed performance
gain of HEDT chips ?)
BUT
