Hi! I bought the controller 4 months ago and it worked well. In the last couple of days the RB button has stopped registering correctly. It registers about 50% of the times, you basically need to double press it to make sure it registered.
I read somewhere that applying wd40 can help, so I sprayed a little bit (I didn't completely remove/open the plate because I didn't want to cause any damage. I opened it slightly before applying the spray). It didn't have any effect.
Is there any viable solution, or am I wasting my time with it?
Thanks!
This is a video of the bug I sent to the ebay seller. Obviously I have no high hopes from that angle. https://drive.google.com/file/d/1GOdj0e-gdmNUnH0UqqV0Q7lyoZY3-1bp/view?usp=sharing
Thanks!
