darkphoenix16
- Oct 16, 2023
- 11 (0.02/day)
Hey there. I am sure you are tired of seeing posts like these. I got a Chinese RX 580 (for free) on Facebook marketplace. The seller said that only one port worked and he wasn't sure if the card would ever work properly so it was given to me at no charge.
I was pretty excited because I consider myself somewhat savvy and thought I could figure it out. Alas, I think I don't have all the knowledge. I spent a long 8 hours on it, and here is what I found.
1. Both DVI and Display Port connections seem to work. The HDMI did not but I didn't put much effort into troubleshooting it.
2. The RAM chips are Elpida memory. Many of the ram chips are faded and you cannot see where they come from, but I assume they are all Elpida
3. The CPU has a code 31939 on it
4. Severe driver timeouts when using an AMD driver. With a fallback driver the card works "fine" although appeared to crash my entire PC when watching a youtube video
5. I have tried a few 2048SP vBIOS roms with Elpida memory support. They all "work" in the same way as above in #4
6. In GPU-Z it looks every typical EXCEPT that the GPU and Mem clocks report 0. Same as the temperature sensor, reports 0.
7. If I flash with a 570 rom then both GPU and Mem clocks report 0 as well as the DEFAULT gpu and memory clocks
8. Booting into linux with this card as the primary display device will cause what appears to be a crashing cycle. I cannot get input into the machine to check a console.
I have since removed the card from my system. Its a bit of work to put in as I have this big GPU in the way that I have to remove, along with this annoying support bracket, to use its PCI slot.
I guess my question is, has anyone seen GPU and Memory clocks report 0 before? I felt there was something wrong with my bios because when I put 570 on there both current and default clocks were 0 instead of just current clocks. Is there any point in me continuing to try and get this card working? That cooler is really cheap, the board looks cheap too. I'm looking for some cheap upgrades for my nephews for xmas and I thought this card would reduce those costs if I could get it working.
Thanks!
Thanks!
