Z170 Intel Micro Code
252 (0.08/day)
Norway
System Name none
Processor AMD R9 9950X
Motherboard GIGABYTE B650E AORUS MASTER
Cooling ARCTIC Liquid Freezer III 420
Memory 32GB G.SKILL @6400MT/s CL32-36-36-28-68 tweaked sub-timings
Video Card(s) ASUS TUF 4090
Storage Samsung PM9A1
Display(s) SAMSUNG 32" IDK WHAT
Case Corsair 7000D
Audio Device(s) none
Power Supply Corsair HX1500
Mouse Corsair
Keyboard Corsair K95 Platinum
Benchmark Scores Check out my YT channel, Technology Hive: https://www.youtube.com/channel/UCeHYX8NGoRj-kZiumUhUsJw
Does anyone know if Microsoft released a micro code through Windows updates to prevent non-k cpu from overclocking? I know Intel has released a micro code in the lastest manufactures' boards. I am getting a Z170 board here soon and I know where to get the overclocking bios to revert to in order to allow overclocking for non-k cpu's. But if Microsoft released an update to stop this also, then things get a little tougher.
Save from the mobo ( if possible ) and other PC parts and get a K CPU .
Yes, that is easy. But I already have a Z97 board with a 4790k in it. I do not need a k cpu. I am building a budget computer for testing. I bought a G4400 cpu along with a Asus Z170-P-D3 board and I have the bios for the board that allows me to overclock that G4400. But, if Microsoft released a micro code update, then this will be tough since I like to keep my systems up to date. Later I may upgrade the CPU, but for now all I want is to overclock that cpu to heat it up and test several thermal pastes for a project :)
I disabled "Windows Update" service on my Windows 10 . Now , from 2nd August , Windows Anniversary update is coming , so I am going to temporarily enable the service in order to get the update .
This trick might help
We will see I guess.
sorry i misunderstood something here?
sorry harry palms
i thought intel microcode updates only comes trough bios
no offense but you are good with this:
ASUS Z170-P D3 Non-K OC BIOS
Support for BCLK Overclocking of CPUs like i3-6100, Pentium G4400, i5-6400, i7-6700 and all other non-K CPUs.
Don’t use this for K-series CPUs.
It might damage your hardware, no guarantees provided.
Issues found so far
  • No IGPU
  • No dynamic change of CPU frequency
  • No C-states
  • No Turbo Mode
  • CPU temperature reading is incorrect
  • AVX instructions have very low performance
  • Windows XP ACPI not supported
After flashing set the following settings to make it boot into OS with correct CPU speed
AdvancedCPU Configuration
- Boot Performance Mode -> Turbo Performance
AdvancedCPU ConfigurationCPU Power Management Configuration
- Intel(R) SpeedStep(tm) -> Disabled
- CPU C states -> Disabled
but ya have bad feelings if the latest microcode is not there?
normally the newest codes are only in modbios
Thanks for sharing, though I already knew all of this. However, Microsoft did release a micro code patch as an update for the Intel G3258 and non "Z" motherboards.
