- Nov 7, 2015
- 6 (0.00/day)
- Wisconsin
Hello!
Just wondering if anyone has any idea what's going on. I did a NVcleaninstall with the following options:
Initial - Recommended
NV Platform Controllers (was not installed on first run, installed it on the second run and wattage is still 80w)
• Disable installer Telemetry & Advertising
• Disable Multiplane Overlay (MPO)
Advanced...
• Disable Driver Telemetry
• Disable NVIDIA HD Audio device sleep timer
• Enable Message Signaled Interrupts (Default/High)
• Disable HDCP
• Use method compatible with Easy-Anti-Cheat
Any ideas why my 125W 4090 is now running at 80W after applying NVcleanstall?
Advanced...
• Disable HDCP
