Zotac 3060 Ti Twin Edge non-OC LHR GDDR6 - request for a new OC LHR BIOS for fan stop
nguyenlucky
5 (0.01/day)
Dear all,
I am using the card in the title, bought in January 2023. When I tried to flash the Twin Edge OC LHR bios from here,
I got artifacts on the screen. Also Device Manager showed Error code 43 for the GPU.
I even tried flashing a non-OC LHR BIOS from another user on hardwareluxx with the same GPU but bought in 2021, also got the artifacts and code 43.
These things suggest that my GPU is a newer revision that requires a different BIOS. Looking on the Internet, I only found a single person with the same problem
This is my current BIOS version. Can someone help me with this?
Here you can find a list with vBios for your model but i am not sure which will work for your GPU.
You can also check the unverified list:
I tried already, there's only one OC LHR bios which causes artifacts.
Only someone with an OC LHR GDDR6 new revision (similar BIOS version to mine) can help me tbh...
