zowie mouse ec2-c ec3-c latency?
fk1ngod
6 (0.00/day)
hi
the zowie imput lag/click latency i thinks wrong. the new zowie ec3-c / ec2-c have ability to change latency in 3 steps :fast response setting, normal response setting and high response setting. The minimun latency is 4 ms with fast response setting evidence occurred on your site: https://www.techpowerup.com/review/zowie-ec3-c/5.html ...but in this site review https://www.rtings.com/mouse/reviews/benq/zowie-ec3-c latency is 14.5 ms very high compared to your tests.
my question is which of the two reviews is the most correct? 14.5 ms latency on new mouse zowie 2022 is very bad
hi
Mine is correct. Rtings is measuring click latency by audio, which is incredibly inaccurate. For instance, they have the Burst Core at 6 ms, yet the Burst Pro at 9 ms. Both mice are using the same switches, have the same buttons, and have the exact same click latency. The FK1-B is listed at 9 ms, whereas the FK2-B is listed at 14 ms, which is impossible given they're the exact same mouse (same internals, different shell). I'm not sure how their click latency chart made it past any sort of quality control, as it's not even internally consistent.
idk here rtings he put the answer on my comment https://www.rtings.com/mouse/discussions/oG07t2gDqaJyhCpX/zowie-ec3-c-ec2-c-latency
are you sure that 4 ms set on fast responde setting?
