20-pin ATX PSU and a 24-pin EATX mobo
Discussion in 'General Hardware' started by adulaamin, Jan 21, 2012.
  1. adulaamin
    adulaamin
    Aug 1, 2009
    818 (0.34/day)
    385
    Baguio City, Philippines
  2. Jetster
    Jetster
    Jan 17, 2010
    7,343 (3.31/day)
    3,767
    Oregon
    Yes. As long as it has a 4 pin 12v plug next to the CPU
    adulaamin says thanks.
  3. Fitseries3
    Fitseries3 Eleet Hardware Junkie
    Oct 6, 2007
    15,515 (5.08/day)
    3,119
    Republic of Texas
    most likely. try it... worst thing that will happen is it may not power up. but im pretty sure it will
  4. adulaamin
    adulaamin
    Aug 1, 2009
    818 (0.34/day)
    385
    no negative effects whatsoever? i also plan on running the PC 24/7... :)
  5. Jetster
    Jetster
    Jan 17, 2010
    7,343 (3.31/day)
    3,767
    Oregon
    Well you dint say what CPU your using. But as long as its not the higher end and you don't overclock. The only negative effects would be heat. It will be fine. You can run a 24 pin off of 20 pins. Just don't force it in the wrong holes
  6. Mussels
    Mussels Moderprator Staff Member
    Oct 6, 2004
    44,267 (10.67/day)
    11,434
    Australalalalalaia.
    it'll be fine at those power levels. just make sure you connect the extra 4 pin near the CPU socket.
    10 Year Member at TPU
  7. adulaamin
    adulaamin
    Aug 1, 2009
    818 (0.34/day)
    385
    7750BE... it will stay on stock... :)
    I got the pc running... thanks for all the input... TPU rocks :rockout: :)
  8. theonedub
    theonedub habe fidem
    Apr 30, 2009
    7,642 (3.08/day)
    4,709
    The main thing you want to avoid when only using a 20pin on a 24pin is a GPU that pulls a full 75w from the PCIe socket.
    Crunching for Team TPU
  9. adulaamin
    adulaamin
    Aug 1, 2009
    818 (0.34/day)
    385
    I'll only be using the onboard so I think I'm ok :)... I'll try crunching with and see how it goes... It'll only serve as a small file server anyways... :)
    theonedub says thanks.
