Basic Guide to Overclocking using Rivatuner
Discussion in 'Graphics Cards' started by newtekie1, Apr 7, 2009.
  1. newtekie1
    newtekie1 Semi-Retired Folder
    Nov 22, 2005
    22,172 (5.94/day)
    8,075
    Try the config file attached to this post.
    10 Year Member at TPU Crunching for Team TPU More than 25k PPD
  2. jrs89 New Member
    Dec 10, 2009
    4 (0.00/day)
    0
    Is it supposed to rebuild the registry database each time I copy over the config file?
    btw, it still doesn't work, I guess this thing just can't be overclocked or something. Thank you for your help, I really do appreciate it.
  3. heavensnight New Member
    Dec 10, 2009
    4 (0.00/day)
    0
    I used the GPU-Z log file while running L4D2. In the attached file you can see that during the majority of the time in the loading screen the settings changed to 3d low power to 2d starting from 10:41:50am, gradually decreasing and then shooting up to 3d full power once the game began at 10:42:04am.
    Is there a way to stop it from defaulting to the 2d settings during the loading screen I wonder?
    EDIT: I managed to get the settings to stick this time, probably because I had restarted the computer since. Unfortunately the crashing still happened when I played L4D2 right after to test :(
  4. deogr New Member
    Sep 3, 2010
    4 (0.00/day)
    0
    when i click customize i only get these widnows:
    low-level refresh rate settings
    low-level desktop color schemes
    graphic subsystem diagnostic report
    reload display drivers
    what did i do wrong or cant this graphic be tweaked or something
  5. newtekie1
    Nov 22, 2005
    22,172 (5.94/day)
    8,075
    What are your full system specs and driver version?
  6. deogr New Member
    Sep 3, 2010
    4 (0.00/day)
    0
    driver version is 258.96
    graphic is GeForce 9400 M G
  7. newtekie1
    Nov 22, 2005
    22,172 (5.94/day)
    8,075
    Your graphics card might not be supported since it is a mobile card.
  8. deogr New Member
    Sep 3, 2010
    4 (0.00/day)
    0
    so when i buy the GTX 470 i wont have any problems?
  9. newtekie1
    Nov 22, 2005
    22,172 (5.94/day)
    8,075
    You shouldn't, I use it with my GTX 470.
    Although at this point I find MSi Afterburner and eVGA Precision to be better for the newer GTX400 cards. Rivatuner has gone so long without an update that it doesn't offer some of the nice features, like voltage control, and the others offer.
  10. deogr New Member
    Sep 3, 2010
    4 (0.00/day)
    0
    so you have your GTX 470 1GB max overclocked/rigged?
    can you tell me what values you got... cuz i am getting my 470 1gb soon and i will probably set the same then...
    So which program is the best ( has the most options)
    MSI or eVGA in your oppinion
  11. newtekie1
    Nov 22, 2005
    22,172 (5.94/day)
    8,075
    815/1000(Core/Memory) are my final 24/7 overclocks. The memory might have more in it, but I didn't bother to push futher.
    MSI Afterburner is the better program, IMO.
    NirvanaA says thanks.
  12. NirvanaA New Member
    Nov 29, 2011
    7 (0.00/day)
    0
    Every where
    Hi.
    please help me.
    [​IMG]
    I can not set RivaTuner for ATI6790!
    What I doing???
  13. Darkleoco
    Darkleoco
    Sep 18, 2011
    1,619 (1.01/day)
    250
    Cullowhee, North Carolina
    Why do choose to revive a thread that is over a year old? Rivatuner has become dated since this thread was dated and you would be much better off simply searching for a guide on how to overclock with MSI Afterburner.
  14. NirvanaA New Member
    Nov 29, 2011
    7 (0.00/day)
    0
    Every where
    Thanks for rep:toast:
    I using RivaTuner-GPUMonitor for PC.
    What I set This???
  15. newtekie1
    Nov 22, 2005
    22,172 (5.94/day)
    8,075
    Rivatuner doesn't support the HD6000 series. It is best to use MSI Afterburner.
  16. NirvanaA New Member
    Nov 29, 2011
    7 (0.00/day)
    0
    Every where
    Please insert a best complet gadget for 6790???
