Belkin 54g wireless issues
Ketxxx
Heedless Psychic
11,521 (1.74/day)
Kingdom of gods
System Name Ravens Talon
Processor AMD R7 3700X @ 4.4GHz 1.3v
Motherboard MSI X570 Tomahawk
Cooling Modded 240mm Coolermaster Liquidmaster
Memory 2x16GB Klevv BoltX 3600MHz & custom timings
Video Card(s) Powercolor 6800XT Red Devil
Storage 250GB Asgard SSD, 1TB Integral SSD, 2TB Seagate Barracuda
Display(s) 27" BenQ Mobiuz
Case NZXT Phantom 530
Audio Device(s) Asus Xonar DX 7.1 PCI-E
Power Supply 1000w Supernova
Benchmark Scores Fast. I don't need epeen.
Nope, it doesnt have much from what I can see. I'm gonna take my adapter to the other PC to mess around in a window some more
panchoman
Sold my stars!
9,595 (1.56/day)
Processor Amd Athlon X2 4600+ Windsor(90nm) EE(65W) @2.9-3.0 @1.45
Motherboard Biostar Tforce [Nvidia] 550
Cooling Thermaltake Blue Orb-- bunch of other fans here and there....
Memory 2 gigs (2x1gb) of patriot ddr2 800 @ 4-4-4-12-2t
Video Card(s) Sapphire X1950pro Pci-E x16 @stock@stock on stock
Storage Seagate 7200.11 250gb Drive, WD raptors (30/40) in Raid 0
Display(s) ANCIENT 15" sony lcd, bought it when it was like 500 bucks
Case Apevia X-plorer blue/black
Audio Device(s) Onboard- Why get an sound card when you can hum??
Power Supply Antec NeoHe 550-manufactured by seasonic -replacement to the discontinued smart power series
Software Windows XP pro SP2 -- vista is still crap
interesting, what is your routers model #? it should say that on the back.
its possible that the adapter is at fault as well, but lets see what happens.
1,700 (0.28/day)
I bought my router in Austria and I can change aswell, just search in your settings :rockout:
Ketxxx
Heedless Psychic
11,521 (1.74/day)
Kingdom of gods
No model number without taking the router apart. Its a propiaty (sp?) POS made in china for BT. I hate British Telecom.
Ed- I just enabled 128bit encryption, so far (touches wood) its holding @ 48MB\s. I bet it wont last.
4,413 (0.68/day)
Processor Intel Core i7-7700K
Motherboard ASUS ROG Strix Z270E Gaming
Cooling Arctic Cooling Freezer i11
Memory 4x 8GB DDR4 Corsair Vengeance LPX @ 2133MHz
Video Card(s) 2x NVIDIA GTX 1080 Ti FEs
Storage 512GB SSD, 2x2TB HDD
Display(s) AOC U2879VF, AOC G2260VWQ6
Case Corsair 750D Airflow Edition
Power Supply EVGA Supernova 850G
Software Windows 10 x64 Pro
Lol, I hear ya :laugh:
Ketxxx
Heedless Psychic
11,521 (1.74/day)
Kingdom of gods
Nope didnt last, just dropped to 36MB\s. Fuck sake.
Ketxxx
Heedless Psychic
11,521 (1.74/day)
Kingdom of gods
Maybe this will help, heres what each setting in this screen is set to;
128
2346
Enabled
Enabled
Auto
Disabled
Disabled
Auto
32
2347
32
Enabled
Enabled
Them settings look right? Of course, I had to set them manually.
1,192 (0.19/day)
scotland
System Name spuds K8-X2
Processor amd athlon X2 4200+ toledo s939 2794mhz 254x11 1.4 vcore
Motherboard MSI K8N Neo4-F v1.0 (MS-7125) nforce4 sata2 mod, laptop cpu heatpipe copper nb cooler
Cooling akasa evo "blue" + 90mm fan, 2x120mm front, 250mm side, 120mm rear, 120mm in psu, pci slot exhaust.
Memory OCZ Platinum XTC DDR PC3200 4GB(4x1024) @254mhz 3-3-3-8 2T
Video Card(s) sapphire HD3870 512mb GDDR4 vf900cu, several ramsinks on components / nvidia 7300gt 256mb secondary
Storage hitachi 160gb (slightly fried) / hitachi 120gb ATA / Seagate 160gb / 2x ps3 seagate 60gb
Display(s) CTX EX1300F 20" flat CRT, 1280x1024@100hz / 19" benq FP91G X / 19" hanns-g (all free)
Case mesh server/gaming black case, 9x 5.25' drive bays, silvestone auto fan controller
Audio Device(s) onboard realtek alc850 7.1/soundblaster LIVE! ct4780 + kxaudio - sony home theatre surround
Power Supply winpower 650w, system draws around 470-500w under load(+all screens)
Software win7 64bit
Benchmark Scores ~16m trips/sec using mty trip generator. triple monitor gaming using SoftTH. 3840x1024
if you want better range and signal try making a cantenna, easy to do, directional so its a bit more secure,
Ketxxx
Heedless Psychic
11,521 (1.74/day)
Kingdom of gods
Good idea. But as my adapter is only like 10 meters away from the hub at best, doesnt seem like the effort would hold much benefit. This adapter is supposed to have a 100 meter range.
1,192 (0.19/day)
scotland
Software win7 64bit
10 meters? lol, this can extend it 1000+ meters los
Ketxxx
Heedless Psychic
11,521 (1.74/day)
Kingdom of gods
My adapter has a 100 meter range, of which its only 10 meters away tops, so there shouldnt be any signal problem period. It cant be that fucked up.
1,192 (0.19/day)
scotland
Software win7 64bit
electrical noise, interference maybe, many things can cause that,
5,052 (0.79/day)
Manchester, United Kingdom
Processor AMD FX 8320 @ 4GHz
Motherboard Gigabyte GA-990FXA-UD5 rev1
Cooling Corsair H70
Memory 4 x 4GB DDR3 Ripjawz 1600Mhz
Video Card(s) Sapphire Vapor-X AMD R9 280X
Storage 1 x 500GB Samsung Evo 850, 1 x 500GB Vrap Data Drive, 3 x 2TB Seagate, 1 x 1TB Samsung F1
Display(s) 3 x DGM IPS-2402WDH
Case Coolermaster HAF X
Power Supply Coolermaster 1000W Silent Pro M
Keyboard Logitech G510
128
2346
Enabled
Enabled
Auto
Disabled
Disabled
Auto
32
2347
32
Enabled
Enabled
Those settings are pretty much useless mate. It's the settings of the access point that matter most. The adapters just change their settings to work with the access point they connect to.
Ketxxx
Heedless Psychic
11,521 (1.74/day)
Kingdom of gods
Then, the word shit comes to mind... my hub has zero options for being able to change channels. the BT software is very limited in what it will let you do with the hub.
imperialreign
7,043 (1.15/day)
Sector ZZ₉ Plural Z Alpha
System Name УльтраФиолет
Processor Intel Kentsfield Q9650 @ 3.8GHz (4.2GHz highest achieved)
Motherboard ASUS P5E3 Deluxe/WiFi; X38 NSB, ICH9R SSB
Cooling Delta V3 block, XPSC res, 120x3 rad, ST 1/2" pump - 10 fans, SYSTRIN HDD cooler, Antec HDD cooler
Memory Dual channel 8GB OCZ Platinum DDR3 @ 1800MHz @ 7-7-7-20 1T
Video Card(s) Quadfire: (2) Sapphire HD5970
Storage (2) WD VelociRaptor 300GB SATA-300; WD 320GB SATA-300; WD 200GB UATA + WD 160GB UATA
Display(s) Samsung Syncmaster T240 24" (16:10)
Case Cooler Master Stacker 830
Audio Device(s) Creative X-Fi Titanium Fatal1ty Pro PCI-E x1
Power Supply Kingwin Mach1 1200W modular
Software Windows XP Home SP3; Vista Ultimate x64 SP2
Benchmark Scores 3m06: 20270 here: http://hwbot.org/user.do?userId=12313
outta curiosity - what kinda appliances you got near your rig - like, in the same room? On the same note - there aren't any public utility service points near your home, like a sewage/water pump house, grid transformer, etc?
Ketxxx
Heedless Psychic
11,521 (1.74/day)
Kingdom of gods
Nope as far as I know theres nothing like that near me. Only things near(ish) the wireless adapter are a single cordless phone and TV, but their way up out the way in comparison to where the adapter is.
panchoman
Sold my stars!
9,595 (1.56/day)
hmm, you're better off getting a new router, provided that the adapter works fine. cause you cant get an upgrade for the firmware, or change the settings and its not working well so yeah
Ketxxx
Heedless Psychic
11,521 (1.74/day)
Kingdom of gods
I may see about a firmware upgrade.. might pop the hood on the hub as well to see who makes it and get proper drivers for it that way.
imperialreign
7,043 (1.15/day)
not a bad idea, actually - it's a little unusual for an adapter to just . . . lose it's bandwidth. The adapter itself might be bad, a defect in the PCB, y'know?
Ketxxx
Heedless Psychic
11,521 (1.74/day)
Kingdom of gods
Ok the chip the USB adapter uses is a ZyDAS 1211B-QF, if somebody can track down a firmware for that all my problems should go away. I already have the drivers, but finding the firmware is proving difficult.
2,996 (0.47/day)
System Name COLOSSUS-MK4
Processor E8400 @4.4 GHz - FSB @550 MHZ
Motherboard Asus P5K Premium (Black Pearl)
Cooling Xigmatek HDT-S1283
Memory 2x1GB Geil BlckDrgn 800 @1158 5-5-5-18
Video Card(s) 8800GT 512MB @740/1782/2080
Storage Hitachi T7K250 250GB & 7200.10 Seagate 250GB
Display(s) Gateway FPD1975W 19" Widescreen
Case Antec 1200
Audio Device(s) Xi-FI Xtreme Audio
Power Supply CoolerMaster IGreen 500W
Software XP Home SP3
Benchmark Scores SuperPi: 10.563 Sciencemark: 2563.14
Well, doesn't here. No routers I've seen in UK let you do it.
Wrong. You can on most routers. Sometimes it is called the SSID channel.. I think. I have changed channels on Netgear router, Linksys, Belkin, and my BThomeHub (which is rubbish btw) Get a better aerial Ket. I suggest no less than 7dBi. (scan.co.uk have one for about £6)
Ketxxx
Heedless Psychic
11,521 (1.74/day)
Kingdom of gods
Oh great.... the BT hub is a POS (I kinda suspected this... but still) I already pulled the POS apart once, the BT hub has a broadcom chip in it, so if someone could track down a firmware and drivers for it using that chip as a base... just might be alright. Looks like I may have to contact BT then and get them to send me a v1.5 hub ( mines 1.0 :wtf: ) and hope its better. While I'm at it I'll be bitching at BT about my connection, its supposed to be 8MB, and any speedtest I do (including BTs own) it never gets above 2.2MB, and BT call that "acceptable" :rolleyes: BS I say, BS!
Ketxxx
Heedless Psychic
11,521 (1.74/day)
Kingdom of gods
Ok, hows this sound for a hammering at BT;
"Hi,
I've just got around to setting up the BT home hub (not the 1.5 version of the hub, its the older one) after a change of hardware from a previous BT package that used the Voyager 105 DSL modem. For a long time period before the switch (probably 3-4 months) I noticed the connection connecting at VERY low speeds (1.7-3.1MB) nomatter the time of day or night. I put this down to the Voyager 105 modem not being able to handle the full speed of the connection I'm supposed to have which is 8MB. However now I've changed to the BT home hub the situation has not improved, and indeed worsened. The BT home hub is junk, its totally incapable of even providing a clean strong signal to a wireless adapter thats no more than 10 meters away from the hub, and can't even maintain a stable bandwidth as a result. There are no devices or objects (TV, cordless phone, magnets etc) in that range or area that would interfere with the signal.
Compounding to this is the fact of the EXTREMELY slow speeds of the connection, its nowhere even close to 8MB. Running the very widely known and well respected speedtest on Speedtest.net shows the connection to be no better than a 2MB connection!?! I have also run your own speed test included with the home hub software and its results are very similar, 1.9MB! Your software reports this as "acceptable", but I'm sorry to say, a connection thats operating at less than 28% of its maximum capability is NOT acceptable. I fully understand no connection will ever be able to run at its full speed, but an 8MB connection thats only operating of up to around 30% is clearly unacceptable under any circumstances. When I first had this 8MB connection it connected at 5.4MB or better, this was an "acceptable" speed, being that it was operating at around 68%. If these issues cannot be resolved I want the price I'm paying per month for this 8MB connection reduced - significantly."
5,052 (0.79/day)
Cooling Corsair H70
Can I please point something out? It's ADSL, 99% of people get less than 3Mb on a supposed 8Mb connection in the UK, and it's unfortunate that cable is only available to such a small number of people. I pay for 20Mb and get the full 20Mb.
The gadget show is current doing a campaign to highlight the best and worst ADSL broadband providers. Get on the website, run the speedtest and submit the result.
It may not do much, but it's a step in the right direction for us in the UK.
Ketxxx
Heedless Psychic
11,521 (1.74/day)
Kingdom of gods
I used to get 5.4MB or better, so BT can do it, their just being knobs in my case. Got a link for that test thing? cant find it on their site.
