SabreWulf69
- Jan 23, 2010
- 358 (0.07/day)
- Cooloongup, Western Australia
System Name | GET FUCKED |
Processor | GET FUCKED |
Motherboard | GET FUCKED |
Cooling | GET FUCKED |
Memory | GET FUCKED |
Video Card(s) | GET FUCKED |
Storage | GET FUCKED |
Display(s) | GET FUCKED |
Case | GET FUCKED |
Audio Device(s) | GET FUCKED |
Power Supply | GET FUCKED |
Software | GET FUCKED |
Benchmark Scores | GET FUCKED |
Amps Watts Volts Conversion Guide
Converting Watts to Amps
The conversion of Watts to Amps is governed by the equation Amps = Watts/Volts
For example 12 watts/12 volts = 1 amp
Converting Amps to Watts
The conversion of Amps to Watts is governed by the equation Watts = Amps x Volts
For example 1 amp * 110 volts = 110 watts
Converting Watts to Volts
The conversion of Watts to Volts is governed by the equation Volts = Watts/Amps
For example 100 watts/10 amps = 10 volts
Converting Volts to Watts
The conversion of Volts to Watts is governed by the equation Watts = Amps x Volts
For example 1.5 amps * 12 volts = 18 watts
Converting Volts to Amps at fixed wattage
The conversion of Volts to Amps is governed by the equations Amps = Watts/Volts
For example 120 watts/110 volts = 1.09 amps
Converting Amps to Volts at fixed wattage
The conversion of Amps to Volts is governed by the equation Volts = Watts/Amps
For Example, 48 watts / 12 Amps = 4 Volts
Explanation
Amps are how many electrons flow past a certain point per second. Volts is a measure of how much force that each electron is under. Think of water in a hose. A gallon a minute (think amps) just dribbles out if it is under low pressure (think low voltage). But if you restrict the end of the hose, letting the pressure build up, the water can have more power (like watts), even though it is still only one gallon a minute. In fact the power can grow enormous as the pressure builds, to the point that a water knife can cut a sheet of glass. In the same manner as the voltage is increased a small amount of current can turn into a lot of watts.
Explanation
