EKWB Halts Nickel-Plated Water Block Production
5,123 (0.94/day)
North of Germany
System Name Nexus PC
Processor Intel Xeon E3-1231 v3, 3600 MHz
Motherboard Gigabyte GA-H97-HD3
Cooling Thermalright Macho V2
Memory 24GB DDR3, 1400MHZ CL8
Video Card(s) Sapphire Radeon R9 290
Storage Samsung EVO 960 250gb, EVO 850 250gb, Vertex 3 128gb. 2 TB of Rotational.
Display(s) 1xAsus MX299, 2x Asus MX239, Oculus Rift CV1
Case Sunflower Tower
Audio Device(s) C-Media CMI8738/C3DX
Power Supply Corsair TX850
Mouse Cyborg R.A.T. 7
Software Win7 64Bit Ultimate
1,166 (0.19/day)
Hampton Roads
Processor Xeon x5650
Motherboard SABERTOOTH X58
Cooling Fans
Memory 24 GB Kingston HyperX 1600
Video Card(s) GTX 1060 3GB
Storage small ssd
Display(s) Dell 2001F, BenQ short throw
Case Lian Li
Power Supply X750
Software Mint 19.3, Win 10
Benchmark Scores not so fast...
Not that plating is hard, but its easy to get it wrong. Even bigger companies get crap plating now and again. I know that's not the point, though.
Wrigleyvillain
PTFO or GTFO
7,702 (1.27/day)
Chicago
System Name DarkStar
Processor i5 3570K 4.4Ghz
Motherboard Asrock Z77 Extreme 3
Cooling Apogee HD White/XSPC Razer blocks
Memory 8GB Samsung Green 1600
Video Card(s) 2 x GTX 670 4GB
Storage 2 x 120GB Samsung 830
Display(s) 27" QNIX
Case Enthoo Pro
Power Supply Seasonic Platinum 760
Mouse Steelseries Sensei
Keyboard Ducky Pro MX Black
Software Windows 8.1 x64
Yeah this has been a giant shit storm for weeks. Lot more info at XS too.
43,587 (6.71/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
My CHIV nickel/plexi block has this problem. Clogged the hell out of my CPU block with nickel shavings too. I ended up taking a small wire wheel on a dremel and sanded out the water channel on the block. All is well, though I'm quite dissapointed in this EK block for this reason.
481 (0.09/day)
Kansas
System Name Late 2013 rMBP 13'' w/ 250 GB SSD
Display(s) Dell P2416D @ 2560x1440 & Dell U2211H @ 1920x1080
Audio Device(s) NuForce uDAC-2 w/ Klipsch Promedia 2.1 & Sennheiser HD595
Mouse Logitech G400 @ 1600 DPI
Keyboard Razr Black Widow
Software OS X
And the reporting started at XtremeSystems - EK nickel plate fail, rust\corrosion or? *PICS*
I kept checking that thread every other day to see what EK was going to announce. Very interesting :p
If you read through the thread at XS it sounds like some owners are getting the shaft from EK.
/edit
Didn't see your post Wrigleyvillain, but you're spot on about the shit storm.
10,242 (1.51/day)
Granite Bay, CA
System Name Big Devil
Processor Intel Core i5-2500K
Motherboard ECS P67H2-A2
Cooling XSPC Rasa | Black Ice GT Stealth 240 | XSPC X2O 750 | 2x ACF12PWM | PrimoChill White 7/16"
Memory 2x4GB Corsair Vengeance LP Arctic White 1600MHz CL9
Video Card(s) EVGA GTX 780 ACX SC
Storage Intel 520 Series 180GB + WD 1TB Blue
Display(s) HP ZR30W 30" 2650x1600 IPS
Case Corsair 600T SE
Audio Device(s) Xonar Essence STX | Sennheisser PC350 "Hero" Modded | Corsair SP2500
Power Supply ABS SL 1050W (Enermax Revolution Rebadge)
Software Windows 8.1 x64 Pro w/ Media Center
Benchmark Scores Ducky Year of the Snake w/ Cherry MX Browns & Year of the Tiger PBT Keycaps | Razer Deathadder Black
Can't blame ya erocker. I used to love EK waterblocks, especially when I was running two nickel plated ones on 3870x2's, but I don't agree with the way they're handling this. There are also many more companies that are competing with EK. I hope that this fiasco doesn't completely shut them down, but I do hope it's jarring enough to make them get their act together.
3,612 (0.52/day)
System Name TheReactor / HTPC
Processor AMD 7800x3d 5050Mhz / Intel 10700kf (5.1ghz All Core)
Motherboard ASrock x670e Taichi / ROG Strix z490-e gaming
Cooling HeatKiller VI CPU/GPU Block -2xBlackIce GTX 360 Radiators - Swiftech MCP655 Pump
Memory 32GB G.Skill 6000Mhz DDR5 / 32GB G.Skill 3400Mhz DDR4
Video Card(s) Nvidia 3090ti / Nvidia 2080ti
Storage Crucial T700 2TB Gen 5 / Samsung Evo 2Tb
Display(s) Acer Predator xb271hu - 2560x1440 @144hz
Case Corsiar 550
Audio Device(s) on board
Power Supply Antec Quattro 1000W
Keyboard Corsair Gaming k70
Holy crap. That explains all the freaking shavings I found in my res...and along the main coming off the pump. Damn I need to open up my blocks now.
Well they take them back if they are F'ed up?
I cleaned my loop out thoroughly flushing it several times to get rid of this... I wonder how bad it looks inside the blocks.
Wrigleyvillain
PTFO or GTFO
7,702 (1.27/day)
Chicago
Display(s) 27" QNIX
Case Enthoo Pro
You had better find out. Now.
3,612 (0.52/day)
Case Corsiar 550
damn it. they weren't cheap blocks either... Like $110 from frozencpu.
Cold Storm
Battosai
15,010 (2.48/day)
In a library somewhere on this earth
System Name Haro
Processor AMD 1700x
Motherboard AsRork x370 Taichi
Cooling EK Custom Loop - CPU only
Memory 32gb G-Skill Trident Z
Video Card(s) EVGA 1080 Superclock 2
Storage Too Many
Display(s) Viewsonic VX2450WM-LED 24" & LG 32 IPS
Case Cooler Master Cosmos II
Mouse SteelSeries Rival 500
Software Win10 Pro
Benchmark Scores i5 750 4.62ghz pi runs // Evga FTW p55
Well they have given a 24m on their nickel blocks now.. So, see about a RMA if you want when it's opened.. Also get pictures up! EK is really shafting people and it's one hell of a thing..
I haven't used my 480 block.. I was getting antsy about doing it the past month.. then (FIH) Don, told me about what was going on.. Boom... I'm wanting a resolution.. Because, it wasn't cheap, and I don't want to be down $400 if I use it..
Thatguy
666 (0.14/day)
this whole problem is being cuased by floating ground current. Best thing to do is chassis ground the water blocks. It should stop the problem.
13,791 (1.93/day)
I really don't see a problem here. Ok, sure there might be problems but apparently not all nickle plated blocks are affected. They do give 24 warranty on material so if anything does go wrong it will go wrong in this time and you can use this warranty for it. If it doesn't, well you have a good block. But yeah, i do agree that Eddy should look into the issue and change the provider for this as i don't think he's doing it himself. I'm sure he's using a 3rd party contractor for this job.
Cold Storm
Battosai
15,010 (2.48/day)
System Name Haro
Processor AMD 1700x
Storage Too Many
Software Win10 Pro
Eddy blames The user on this matter. He has from the start.. That's the problem. He's been hiding behind language barriers and playing it off as that.. Then, making it the user that using Silver Coil/PTnuke as the ones that did something wrong.. Then after the factor that there was people that just used distilled.. It's now distilled/silver coil/PTnuke... He can't see the fact it's whats going on in the milling (production) of the block instead.. Hand picked blocks from Eddy even show that their is chips in the drill holes of the G-1/4 barb fittings.. Eddy picked that his self..
they only give 12m warranty.. It's just the factor that he finally had to up it to 24m due to the fact it has dated back since the end of 2009 that the problem started.. He's all ways done 12m and if you use Silver Coil/PTnuke, you may as well kiss the warranty good bye..
Pictures of the block
Post about it being hand picked from Eddy
6,823 (1.27/day)
Viking Land
System Name Ivy Biatch
Processor i5 3570K
Motherboard ASSRockzz z77TOTHEEXTREME!!!!
Cooling bleh
Memory 2x4gb crucial 1866
Video Card(s) HD7770, yes it does BF3
Storage 120gb Vertex
Display(s) 226BW
Case whats that, oh my table
Audio Device(s) stock onboard thing
Power Supply HX850W
Software 7
its more the fact that he wont admit that they have made a mistake and then correct it instantly instead of denying it for so long that its causing so massive damage besides the already bad rep the company has.
Wrigleyvillain
PTFO or GTFO
7,702 (1.27/day)
Chicago
Display(s) 27" QNIX
Case Enthoo Pro
Yeah the bad PR alone over this has killed EK I'm afraid. Eddy kinda did it to himself too.
Cold Storm
Battosai
15,010 (2.48/day)
System Name Haro
Processor AMD 1700x
Storage Too Many
Software Win10 Pro
Yep.. he's done it all to his self.. To the factor that it's not really worth it to buy from them anymore.. If your going to be blamed for something they did.. Sounds like Harry Hank from PPC..
3,612 (0.52/day)
Case Corsiar 550
Well I can't wait to get home and take a part my 2 5870 full coverage blocks. Paid $110 each plus shipping....
I ONLY use distilled water with water wetter (like 2 caps full)...which is supposed to be used for Rust and corrosion protection (Designed for use with all modern aluminum, cast iron, copper, brass and bronze cooling systems), plus adding to heat transfer. IF it is good enough for racing block super heated engines and not oxidize the crap out of them then my blocks should be safe, if not safer.
Man I will be pissed off they look like the images Btarunr posted. :mad:
Cold Storm
Battosai
15,010 (2.48/day)
System Name Haro
Processor AMD 1700x
Storage Too Many
Software Win10 Pro
Yeah... I hope all is good.. post link when you look at it..
Also. on the Warranty
EK RMA upgrade for corrosion - 14/06/2011
RMA is upgraded on two points:
1. We are lifting the RMA limit on corrosion to full 24month from the end-user purchase date without limit.
2. EK will cover all shipping costs of the RMA block to reseller and shipping of the replacement block back to customer.
The procedure of RMA request stays the same; filling the RMA form.
Wonder if they are refunding the money to the people that HAD to pay for rma because Eddy was to t1ght a$$ to say that something was up...
Edit: this reminds me of Gelid Icy Vision block problem...
Wrigleyvillain
PTFO or GTFO
7,702 (1.27/day)
Chicago
Display(s) 27" QNIX
Case Enthoo Pro
6,823 (1.27/day)
Viking Land
Processor i5 3570K
Cooling bleh
Display(s) 226BW
Power Supply HX850W
Software 7
[yt]X-Yd8v2Ub9E[/yt]
will prolly buy AC blocks for my GPU's if i do that :)
Cold Storm
Battosai
15,010 (2.48/day)
System Name Haro
Processor AMD 1700x
Storage Too Many
Software Win10 Pro
5,123 (0.94/day)
North of Germany
I love that vid! Especially the laser Engraver is my favorite,along the CNCs!
And, they listen to Bob (i think so at least) while working, cant hurt the working atmosphere, and the quality of the blocks! :D
newtekie1
Semi-Retired Folder
28,472 (4.23/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
In EK's defence, the "massive damage" that most of use are reacting to was caused by soaking the block in a Sodium Cloride solution, not from real world use. The amount of corrosion that amounts to "massive" was artificially caused in 8 hours, but in reality isn't even close to what you would see after a year+ of real use.
I'm not saying there isn't a problem, because there is, I'm just saying that the "massive damage" isn't really that massive and the images that most people are freaking out about aren't anything that really happened to someone that was using the product normally.
3,612 (0.52/day)
Case Corsiar 550
I don't want to give the impression there was like spoon fulls of shavings in my system... but what I at first thought were some bubbles clinging to the res ended up being silver/metallic flakes sitting at the bottom of my res... The only silver components I have in the system are my nickel coated EK blocks, everything else is copper.
