System Name | PC |
Processor | AMD Ryzen 3600 |
Motherboard | MSI B450 Mortar Max |
Cooling | Phanteks PH-TC12DX, 3 x NZXT FN 140mm, 1x NZXT FV V2 120mm |
Memory | 32gb DDR4 3200mhz |
Video Card(s) | ASUS R9 290 DCII-OC 4GB |
Storage | corsair mp600 1TB |
Display(s) | LG 27MB85Z 27" 1440p |
Case | NZXT Source 340 |
Power Supply | Thermaltake 675w |
Mouse | Logitech G500S |
Keyboard | Logitech G510S |
Software | Windows 8.1 64 bit |
Okay, sorry to make this thread very long. I've just noticed that every so often (maybe 10 minute or so) some texts on certain window, the texts will turn slightly bold for a second or so then disappears. Any clue?
It'll be either an image enhancement setting in your TV, or something to stop the picture burning in.
System Name | Desktop|| Virtual Host 0 |
Processor | Intel Core i5 2500-K @ 4.3ghz || 2x Xeon L5630 (total 8 cores, 16 threads) |
Motherboard | ASUS P8Z68-V || Dell PowerEdge R710 (Intel 5520 chipset) |
Cooling | Corsair Hydro H100 || Stock hotplug fans and passive heatsinks |
Memory | 4x4gb Corsair Vengeance DDR3 1600 || 12x4gb Hynix DDR3 1066 FB-DIMMs |
Video Card(s) | MSI GTX 760 Gaming Twin Frozr 4GB OC || Don't know, don't care |
Storage | Hitachi 7K3000 2TB || 6x300gb 15k rpm SAS internal hotswap, 12x3tb Seagate NAS drives in enclosure |
Display(s) | ViewSonic VA2349S || remote iDRAC KVM console |
Case | Antec P280 || Dell PowerEdge R710 |
Audio Device(s) | HRT MusicStreamer II+ and Focusrite Scarlett 18i8 || Don't know, don't care |
Power Supply | SeaSonic X650 Gold || 2x870w hot-swappable |
Mouse | Logitech G500 || remote iDRAC KVM console |
Keyboard | Logitech G510 || remote iDRAC KVM console |
Software | Win7 Ultimate x64 || VMware vSphere 6.0 with vCenter Server 6.0 |
Benchmark Scores | Over 9000 on the scouter |
System Name | Space Station |
Processor | Intel 13700K |
Motherboard | ASRock Z790 PG Riptide |
Cooling | Arctic Liquid Freezer II 420 |
Memory | Corsair Vengeance 6400 2x16GB @ CL34 |
Video Card(s) | PNY RTX 4080 |
Storage | SSDs - Nextorage 4TB, Samsung EVO 970 500GB, Plextor M5Pro 128GB, HDDs - WD Black 6TB, 2x 1TB |
Display(s) | LG C3 OLED 42" |
Case | Corsair 7000D Airflow |
Audio Device(s) | Yamaha RX-V371 |
Power Supply | SeaSonic Vertex 1200w Gold |
Mouse | Razer Basilisk V3 |
Keyboard | Bloody B840-LK |
Software | Windows 11 Pro 23H2 |
I'm happy to report back that I solved the problem of overscan. In the Menu/Picture/HD Size, I chose "Size 2" and it fixes the overscan issue. It's now working great.
Did you get the flashing and text problems solved? I take it you turned off C.A.T.S.?
Like I explained above it's Contrast Automatic Tracking System. It basically adjusts contrast and lighting on the fly, and it can cause subtle flashing.
System Name | Quantumville™ |
Processor | Intel Core i7-2700K @ 4GHz |
Motherboard | Asus P8Z68-V PRO/GEN3 |
Cooling | Noctua NH-D14 |
Memory | 16GB (2 x 8GB Corsair Vengeance Black DDR3 PC3-12800 C9 1600MHz) |
Video Card(s) | MSI RTX 2080 SUPER Gaming X Trio |
Storage | Samsung 850 Pro 256GB | WD Black 4TB | WD Blue 6TB |
Display(s) | ASUS ROG Strix XG27UQR (4K, 144Hz, G-SYNC compatible) | Asus MG28UQ (4K, 60Hz, FreeSync compatible) |
Case | Cooler Master HAF 922 |
Audio Device(s) | Creative Sound Blaster X-Fi Fatal1ty PCIe |
Power Supply | Corsair AX1600i |
Mouse | Microsoft Intellimouse Pro - Black Shadow |
Keyboard | Yes |
Software | Windows 10 Pro 64-bit |
Thanks, Frag. The video and image look fantastic but it's just the texts -- not sure what's going on.
The pixel orbiter by definition will affect the text, since the pixels sent from the PC aren't aligned with those of the screen. You should and do see the effect on fine detail, such as text. The effect may be more obvious on non-antialased text too, since it has no fuzzy edges to hide things like this.
In short, we need better technology than plasma and LCD for our displays. Those upcoming OLED TVs and monitors should look fantastic and will hopefully solve all the problems at once.
Keyboard | Yes |
System Name | Main Rig |
Processor | Athlon 5350 |
Motherboard | AsRock mITX |
Memory | 4gb |
Storage | 120gb Kingston HyperX SSD |
Display(s) | Samsung Syncmaster 740N |
Power Supply | Corsair 430 watt |
Keyboard | Yes |
They still haven't sorted out the lifetime problem of OLEDs properly, yet. Once they do, it'll likely go mainstream.
I don't know why they can't use the ordinary type of LED instead of these organic types, but there must be a good reason for it, or they would have done so long ago.
