Help! 2x2GB Corsair Ram sticks gives freezing problems with Gigabyte EP45-DS3R Mobo
kostap
12 (0.00/day)
Processor Intel Q6600 G0
Motherboard Gigabyte EP45-DS3R
Cooling Xigmatec HDT-S1283
Memory Corsair TWIN2X4096-6400C4DHX (2X2GB)
Video Card(s) Sapphire RADEON HD 4850
Storage Samsung SpinPoint F1 HD103UJ 1TB
Display(s) HP LP2275W
Case NZXT LEXA
Power Supply Corsair 550W VX Series
It's my first post in this forum so I would like first of all to salute the community.
Now, the reason I make this thread is because my 2x2GB CM2X2048-6400C4DHX Corsair RAM sticks react peculiarly when both of them are mounted on motherboard EP45-DS3R. But let me describe you the problem. When I put the two ram sticks in slots 1 and 3 OR 2 and 4(Dual channel mode) I have a crash on Windows Vista in approximately 0-3 minutes after logging in. If the Ram sticks are in slots 1 and 2 OR 3 and 4 then my system is a bit more reliable and it will crash in 1-4 hours, it depends on load of the system. The thing is that when I remove one of the sticks, then the computer stops these annoying crashes and reacts perfectly. No freeze for more than 48 hours. So I downloaded memtest86+ V2.01 to check if my ram sticks have any problems. After 7 passses for each memory card both finished with no errors at all. But when I started the test with both memory sticks mounted, memtest never made it to finish the test. For case 1 ( slot1 and slot3 OR slot2 and slot4) memtest freeze in less than 20 seconds and with more than 32 errors, while for case 2 (slot1 and slot2 OR slot3 and slot4) with 70-180 errors and freezees at 20-35 minutes.
I have done some adjustments by my own reading some threads which looked like this. Anyway, I've downloaded latest bios version F10 FOR EP45-DS3R and timings are now correct 4-4-4-12 while I had to do that manually before. I setted DRAM Voltage at 2.100V which is manufacturer's recommended setting and nothing else because of the fear that I would make any damages. I am suspicious that Mobo is faulty but before I make any move I would like to share it with you. Any thoughts?
My system:
PSU: Corsair 550W VX Series
Mobo: Gigabyte EP45-DS3R rev1.0
CPU: Intel quad core Q6600 G0 (9X266MHz)
GPU: Sapphire HD 4850 512MB GDDR3 Dual DVI Dual slot cooler HDTV Out PCI-E Graphics Card
RAM: Corsair 4GB (2x2GB) DDR2 800MHz TWIN2X4096-6400C4DHX
HDD: Samsung SpinPoint F1 HD103UJ 1TB Hard Drive SATAII
DVD: Pioneer DVR-216BK 20x DVD±RW Internal SATA
sneekypeet
Retired Super Moderator
29,409 (4.46/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
you could try raising the Northbridge voltage up to 0.10V max more than stock.
kostap
12 (0.00/day)
Case NZXT LEXA
I had several reboots when I try 1.160V which means +0.060 and sometimes I couldn't even reach the Logo or the post screen
HTC
4,604 (0.78/day)
Portugal
System Name HTC's System
Processor Ryzen 5 2600X
Motherboard Asrock Taichi X370
Cooling NH-C14, with the AM4 mounting kit
Memory G.Skill Kit 16GB DDR4 F4 - 3200 C16D - 16 GTZB
Video Card(s) Sapphire Nitro+ Radeon RX 480 OC 4 GB
Storage 1 Samsung NVMe 960 EVO 250 GB + 1 3.5" Seagate IronWolf Pro 6TB 7200RPM 256MB SATA III
Display(s) LG 27UD58
Case Fractal Design Define R6 USB-C
Power Supply Corsair TX 850M 80+ Gold
Mouse Razer Deathadder Elite
Software Ubuntu 19.04 LTS
I have the exact same RAM as you and i don't know about Gigabyte boards but i use 1.35 in NorthBridge (NB) voltage to have it run with 2 sticks in my Rampage Formula and 1.45 with 4 sticks.
1.160 seems rather low for 2 sticks, dude. Where did you get the "stock" NB voltage?
kostap
12 (0.00/day)
Case NZXT LEXA
HTC my motherboard gives as a default value for MCH Voltage 1.100 V. With that setting I get a lot of errors for both memories and finally memtest freezes. I will try with 1.25-1.35V to see any differences. thanks
HTC
4,604 (0.78/day)
Portugal
Try with 1.25 first.
EDIT
YAY: 1K posts :)
EDIT #2
I'm assuming MCH voltage in Gigabyte boards is the exact same as NB voltage in Asus boards. If not, STOP.
To be on the safe side, better ask someone with a Gigabyte board and he's/her input on this.
kostap
12 (0.00/day)
Case NZXT LEXA
HTC I set the MCH voltage at 1.32 and now I have no freezings at all. I am running now with both sticks for over 20 minutes.
Memtest for 10 minutes didn't give any errors and crysis warhead played flawlessly. I hope that was the problem.anything else in your mind?
2,276 (0.36/day)
Cairns QLD, Aussie
System Name GaMEr / HTPC
Processor FX8320 4.5ghz so far NB- 2815mhz / X2 255 @ 3.2ghz (Temp till BD)
Motherboard 990FX-UD5 / GA-MA785GPMT-US2H
Cooling XSPC - 240rad 480rad 5 x 120mm out, 6 x 80mm in / H220-edge 1/2" & 2 x 120mm Magma
Memory 4gb PI 6,8,6,18 1T 1706mhz / 4gb Crucial D9's 1400 @ 6,6,6,18,1T
Video Card(s) 3gb HD7950 / Onboard
Storage 2 x 120gb Sandisk ultra plus 2tb WD / 60gb vertex 2 + 2 x 2tb WD Greens
Display(s) 3x24in Dell Ultra (portrait) / NEC 32" FullHD LCD
Case LL PC71A Full tower / Antec fusion black with Imon remote Modded for WC
Audio Device(s) OB / Auzentech cinema 7.1
Power Supply TT 700w TR2 / TT 600w Litepower modded with Noctua S12 fan.
Software 7 Ult / 7 premium x64
Looks like you have solved the problem, just keep an eye on your nb temps though. Make sure they are not going thru the roof. :)
kostap
12 (0.00/day)
Case NZXT LEXA
Do you know any program dedicated for temps and fan speeds?
MKmods
Case Mod Guru
5,697 (0.96/day)
Nevada
System Name Crossflow III
Processor AMD 965 (4.04Ghz)
Motherboard Asus Crosshair III
Cooling Air
Memory 4 gigs Mushkin 7-7-7-20@1T
Video Card(s) single 9800GT
Storage Raptor 150's in Raid0
Display(s) LG Flatron 24"
Case Custom
Audio Device(s) AuzenTech X-Raider W/OP637
Power Supply Custom modded Corsair 750HX
Software Win 7 64/Solaris Utility
Benchmark Scores 3DMark06--21963 so far
Nice call HTC, and welcome to the spammers club...
kostap
12 (0.00/day)
Case NZXT LEXA
Sorry for many questions but it is my first time after many years using Desktop again and I don't know too much about manual settings on bios etc. In old days you hadn't got to adjust voltages....But thanks anyway guys you are very kind and faaaast
MKmods
Case Mod Guru
5,697 (0.96/day)
Nevada
Cooling Air
Case Custom
kostap
12 (0.00/day)
Case NZXT LEXA
Thank you MKmods, I appreciate that.
MKmods
Case Mod Guru
5,697 (0.96/day)
Nevada
Cooling Air
Case Custom
ur welcome and welcome to TPU...:toast:
